Zoek.exe v5.0.0.2 Updated 03-May-2018(Online Version)
Tool run by Zagi on 12.01.2021 at 23:45:07,14.
Microsoft Windows 10 Pro 10.0.19041 x64
Running in: Normal Mode Internet Access Detected
Launched: I:\Filmy\zoek (1).exe [Scan all users] [Script inserted]
==== System Restore Info ======================
12.01.2021 23:46:07 Zoek.exe System Restore Point Created Successfully.
==== Reset Hosts File ======================
# Copyright (c) 1993-2006 Microsoft Corp.
# space.
# lines or following the machine name denoted by a '#' symbol.
# For example:
# localhost name resolution is handled within DNS itself.
127.0.0.1 localhost
::1 localhost
==== Empty Folders Check ======================
C:\PROGRA~3\SoftwareDistribution deleted successfully
C:\PROGRA~3\ssh deleted successfully
C:\Users\Zagi\AppData\Local\DBG deleted successfully
C:\Users\Zagi\AppData\Local\PeerDistRepub deleted successfully
==== Deleting CLSID Registry Keys ======================
==== Deleting CLSID Registry Values ======================
==== Deleting Services ======================
==== Deleting Files \ Folders ======================
C:\Users\Zagi\AppData\Roaming\uTorrent deleted
C:\PROGRA~2\COMMON~1\Wondershare deleted
C:\PROGRA~3\Package Cache deleted
C:\Users\Zagi\AppData\Local\Wondershare deleted
C:\Users\Zagi\AppData\Local\cache deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\CM21511.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\CM25572.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\CM2672.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\CM2ADCB.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\CM2B10.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tpm-2b1c-13f0-5ecfb41.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-24c4-2458-1b59ce6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d28cb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d28dd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d28df.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2900.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2902.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2904.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2915.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2917.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2929.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d292b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d292d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d293f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2950.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2952.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2954.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2966.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d2968.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d296a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1070-2a3c-63d297c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f0e5c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f0f0a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f0f89.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1008.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f10c6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1154.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1166.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1177.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f11a8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f11ba.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f11cc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f121c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f124d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1358.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1629.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1735.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1765.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1777.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1214-2a20-f1789.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998a5f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998abf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998aff.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998b30.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998baf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998c1f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998c5f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998caf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998cc1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998cf2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998d13.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998d25.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998d56.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998d58.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998d69.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998daa.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998dcb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998e0b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-14b0-16b4-a998e3c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-126506db.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-1265074a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-1265077b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-126507bb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-126507fc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-1265081d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-1265084e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-1265086f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650891.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-126508c1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-126508f2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650942.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-126509b2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650a21.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650a91.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650ac1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650b12.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650b91.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1690-1e84-12650bf0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea1a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea2b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea2d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea3f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea41.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea53.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea55.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea66.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea68.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea6a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea8c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea8e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39ea90.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39eaa1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39eaa3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39eaa5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39eab7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39eab9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-17e0-1a50-39eabb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149946cb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149946dc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149946ee.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-1499470f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-14994711.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-14994723.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-14994734.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-14994736.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-14994758.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-14994769.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-1499476b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-1499478c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-1499479e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149947a0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149947b2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149947c3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149947c5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149947d7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-18e0-2618-149947e9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97c08.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97c19.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97c3a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97c5c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97c7d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97c8f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97ca0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97cc1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97cf2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97d62.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97d73.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97d75.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97d97.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97db8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97dc9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97ddb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97ddd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97def.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1c38-1fac-97e00.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a7597.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a75c8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a75e9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a75fb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a761c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a763d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a765e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a7680.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a76a1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a76b3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a76e3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a7705.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a7716.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a7747.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a7788.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a7799.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a77da.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a780b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1cb0-195c-c5a783c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1c5e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1c70.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1c91.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1cb3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1cd4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1cf5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1cf7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d09.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d1a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d2c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d2e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d40.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d51.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d53.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d65.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d76.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d78.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d9a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1eb8-26b0-a1d9c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2968.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29a9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29bb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29bd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29ce.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29d0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29e2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29e4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29e6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e29f7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a09.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a0b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a0d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a1f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a30.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a52.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a63.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a65.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1f64-2194-1a2e2a77.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc49bb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc49cd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc49de.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc49e0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc49f2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc49f4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a06.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a17.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a19.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a2b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a2d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a3e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a40.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a52.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a54.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a66.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a68.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a79.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-1fe8-2b14-17dc4a8b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab35a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab36c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab36e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab37f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab381.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3a3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3b4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3b6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3c8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3d9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3eb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3ed.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab3ff.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab401.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab422.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab434.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab436.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab447.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2064-1244-bdab449.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a4582.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a45a3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a45c4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a45d6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a45e7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a45f9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a461a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a463c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a464d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a465f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a4680.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a4692.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a46a3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a46d4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a46e6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a4717.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a4738.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a474a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-22e8-23a8-a475b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b911.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b922.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b934.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b945.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b947.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b959.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b95b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b96d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b97e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b980.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b992.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b994.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b9a6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b9b7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b9b9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b9ea.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b9ec.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9b9fe.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2374-10e8-9ba00.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699885.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699897.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-336998a8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-336998ba.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-336998cc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-336998ce.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-336998df.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-336998f1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699903.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699905.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699916.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699928.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699939.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-3369993b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-3369994d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-3369995f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699970.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699972.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-23c4-1b88-33699984.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c8fb0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9000.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9002.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9033.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9074.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9095.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c90a7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c90b8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c90ba.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c90eb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c912c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c912e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c916e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9180.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9182.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9184.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9195.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c9197.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-242c-12bc-c91a9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bc9d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bcae.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bcc0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bcd2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bcd4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bce5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bcf7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bcf9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd0a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd1c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd1e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd30.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd41.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd53.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd55.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd67.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd78.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd7a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2464-998-932bd8c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e457.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e468.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e47a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e47c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e47e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e490.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e492.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4a3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4b5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4c6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4c8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4ca.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4dc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4de.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4f0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e4f2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e503.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e505.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2480-2490-9e517.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-24c4-2458-1b575de.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-24c4-2458-1b575ff.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-24c4-2458-1b57611.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-24c4-2458-1b57622.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9590e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95920.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95922.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95924.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95936.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95938.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9593a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9594b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9594d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9594f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95961.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95963.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95965.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95977.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95979.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9597b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9598c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-9598e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-26a0-2ab8-95990.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-572f8bb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-572fb5d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-572fc78.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-572fcd8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-572fe60.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-572ff0e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57301ef.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57302ac.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57302fc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57303e9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57305bf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5730823.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5730b13.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5730e61.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5730f6c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5730fbc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-573100c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731157.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57311c6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731226.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731285.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731304.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731335.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57313f3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731453.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57314a3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731764.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57317a4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731823.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731ac5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731d09.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731df6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731e46.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731fbf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5731ff0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732169.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732785.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732852.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-573297d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57329fc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732a5c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732a8d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732b2b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732baa.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732c0a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732d35.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732d46.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732f0d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5732f8c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57330d7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5733240.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5733290.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57332c1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-57332e2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5733313.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5733325.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2790-1fe0-5733336.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed896b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed898d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed89ae.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed89cf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8a10.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8a12.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8a23.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8a25.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8a56.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8a87.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8a89.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8aaa.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8aac.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8abe.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8ac0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8ad2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8af3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8af5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-27c8-1dd0-15ed8b06.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953c76.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953c88.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953c99.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953cab.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953cbd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953cbf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953cd0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953ce2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953cf3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953cf5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d07.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d19.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d1b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d2c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d3e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d40.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d52.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d63.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2850-254c-6953d65.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd5d6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd5f7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd619.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd659.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd65b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd66d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd67e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd680.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd692.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd694.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd6a6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd6a8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd6b9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd6bb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd6cd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd6df.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd6f0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd702.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd713.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd715.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd727.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd739.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd74a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd75c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd76e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd770.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd781.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd793.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd7a4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd7a6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd7b8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd7ca.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd7db.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd7ed.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd7ff.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd820.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd89f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8b0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8b2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8c4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8c6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8d8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8da.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8eb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8ed.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd8ef.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd901.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd903.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd915.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd917.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd928.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd92a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd93c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd93e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd94f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd951.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-28e0-2a10-37dd953.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fc8c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fcae.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fcb0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fcc1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fcc3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fcd5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fcd7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fce9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fceb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fcfc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd0e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd10.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd21.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd33.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd45.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd47.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd58.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd6a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2910-84c-14fd7c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96860.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96891.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-968b2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-968d4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96924.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96926.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96937.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96949.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-9694b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-9695d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-9698e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-9699f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-969ef.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96a11.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96a22.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96a34.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96a55.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96a76.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-29b4-2b24-96a88.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb2110.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb21ae.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb222d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb226e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb229f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb22cf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb2300.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb2360.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb23c0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb244e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb24ae.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb24fe.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb252f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb257f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb25ef.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb264e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb269f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb271e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2a44-226c-4bb27ac.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2b1c-13f0-5ecfafc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2b1c-13f0-5ecfb1d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2b1c-13f0-5ecfb2f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2b1c-13f0-5ecfb40.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be8ff5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9055.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be90b5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9153.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be91c2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be91f3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9243.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9320.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be938f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be942e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be949d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be95a9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9712.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be97df.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be986e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be99e7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9aa4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9ad5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2bd8-1100-3be9b06.tmp deleted
Po zapnutí PC někdy neběží monitory
- Level 2.5
Re: Po zapnutí PC někdy neběží monitory
MB: MSI B250 PC MATE
CPU: Intel Pentium G4560
GPU: SAPPHIRE RX580 8GB NITRO+
RAM: 2x8GB Kingston HyperX Fury Black 8GB DDR4 2133MHz
PSU: Seasonic SS.500ET-T3-500W, Energy Knight
HDD: SAMSUNG HD103SJ ATA Device - 1TB
SSD: Kingston Now UV400 - 120GB
Case: SilentiumPC Regnum RG1 Pure Black
- Level 2.5
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b1e8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b248.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b288.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b2aa.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b4ee.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b53e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b57e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b5bf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b5ff.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b621.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b6cf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b70f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b76f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b780.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b7a2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b7c3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b7e4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b805.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2cec-284c-56d3b817.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b7341a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73499.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73595.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73623.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b736a2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b736c4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b736d5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b736f6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73718.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73758.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b737a8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b737ba.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b737db.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b737ed.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b737fe.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73820.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73851.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b73872.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2ef4-914-8b738d2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d639.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d67a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d68b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d69d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d6be.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d6d0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d6e1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d712.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d743.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d755.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d795.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d7a7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d7a9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d7ca.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d7fb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d7fd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d80f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d811.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f60-3348-5cc6d832.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081a1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081a3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081b4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081b6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081c8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081ca.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081cc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081de.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081e0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081f1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081f3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-110081f5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-11008207.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-11008209.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-1100820b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-1100821d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-1100821f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-11008230.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-2f64-9d8-11008232.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-5283ff95.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-5283fff5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840045.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840076.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-528400b6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840106.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840195.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840281.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-528402d1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-5284037f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-5284041d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-5284045e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-5284049e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-528404df.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-528404f1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840502.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840523.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840535.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-31c-2778-52840537.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855721.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e85584c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e8559d4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855a53.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855b40.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855bed.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855c8c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855d59.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855e93.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855ec4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855f24.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855f36.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855f47.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855f59.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e855fb9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e856038.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e8560e5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e856174.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-3338-1da0-2e8561d4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-5384d9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-5384eb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-5384fd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-5384ff.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538501.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538512.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538514.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538526.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538528.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-53853a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-53853c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-53854d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-53854f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538561.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538563.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538565.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538576.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-538578.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-530-2148-53858a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f19.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f1b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f1d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f1f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f30.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f32.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f34.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f36.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f38.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f4a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f4c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f4e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f50.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f52.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f64.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f66.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f68.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f6a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-5bc-5c0-34f6c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba2f7f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba2fa0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba2fb2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba2fc3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba2fc5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba2fe7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba2fe9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba300a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba300c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba301e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba3020.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba3031.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba3043.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba3045.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba3056.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba3058.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba305a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba306c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-6c8-2edc-5ba306e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d28e3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2904.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2916.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2918.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2939.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d293b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d295c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d296e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2970.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2972.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2984.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2986.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2997.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d2999.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d29ab.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d29ad.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d29be.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d29c0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-8ec-798-d29d2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d20d7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d2107.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d2129.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d214a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d217b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d219c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d21bd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d21ee.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d220f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d2250.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d22bf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d230f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d236f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d2390.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d23b2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d23d3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d23f4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d2435.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-92c-1278-1d2446.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b4e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b50.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b62.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b64.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b66.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b78.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b7a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b7c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b8d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96b8f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96ba1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96ba3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96ba5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96bb6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96bb8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96bba.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96bcc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96bce.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-998-900-96be0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebb63.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebb85.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebbb5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebbe6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebc08.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebc67.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebcb7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebd65.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebd96.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebdc7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebe65.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebeb5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebf44.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebf65.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebf87.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebfc7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebfc9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebfdb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a28-1c94-284ebffc.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bfde4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bfe63.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bfe75.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bfe96.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bfed7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bfef8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bff19.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bff3a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2bffc9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c0058.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c00f6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c09c2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c09e3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c0a04.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c0a16.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c0a37.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c0a49.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c0a6a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-a8c-19ec-2c0a7c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322aef.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b01.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b03.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b15.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b26.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b28.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b3a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b3c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b4d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b4f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b61.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b63.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b75.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b77.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b88.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322b8a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322bac.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-aa4-2b74-48322bae.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e270.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e281.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e283.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e285.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e297.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e299.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e2aa.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e2ac.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e2be.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e2c0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e478.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e7e5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e854.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32e931.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32ea3c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32eabb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32eca2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32eea7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-b14-2fd8-d32eec9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ed617.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ed83c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ed87d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ed8bd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ed91d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212edc0d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212edd09.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212edd1a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212edd2c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212edd6d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212edfb1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ee408.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ee477.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ee554.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ee612.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ee837.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212ee9cf.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212eeec2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c2c-9dc-212eeee4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0dc9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0dfa.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0e4a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0e5c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0e5e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0e9f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0eb0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0ed1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0ed3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0ee5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0ef7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0f08.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0f0a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0f5a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0f6c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0f6e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0f80.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0fa1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-c88-2290-d0fb3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-74649c7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-74649f8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464a0a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464a2b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464a3d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464a6e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464a8f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464b3d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464bfa.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464cd7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464cf8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464d29.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464e73.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7464f40.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-746506b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-7465261.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-74653ab.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-746540b.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-d28-a08-746541d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a1892.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a18a4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a18a6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a18b8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a18ba.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a18cb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a18cd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a18df.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a197d.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a198f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19a0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19a2.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19b4.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19b6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19c8.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19ca.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19db.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19dd.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-e20-2700-430a19ef.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ebf6.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ec08.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ec29.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ec4a.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ec4c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ecac.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ecae.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ecc0.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ecd1.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ece3.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ece5.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ece7.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ecf9.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ecfb.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ed0c.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ed1e.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ed2f.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ed31.tmp deleted
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\tw-f1c-7cc-4c04ed43.tmp deleted
"C:\DumpStack.log.tmp" not deleted
==== Chromium Look ======================
Google Chrome Version: 87.0.4280.141
Chrome Media Router - Zagi\AppData\Local\Google\Chrome\User Data\Default\Extensions\pkedcjkdefgpdelpbcmbmeomcjbeemfm
==== Set IE to Default ======================
Old Values:
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"Start Page"="http://go.microsoft.com/fwlink/p/?LinkId=255141"
New Values:
==== All HKLM and HKCU SearchScopes ======================
HKLM\SearchScopes "DefaultScope"="{0633EE93-D776-472f-A0FF-E1416B8B2E3A}"
HKLM\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} - http://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
HKLM\Wow6432Node\SearchScopes "DefaultScope"="{0633EE93-D776-472f-A0FF-E1416B8B2E3A}"
HKLM\Wow6432Node\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} - http://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
HKCU\SearchScopes "DefaultScope"="{0633EE93-D776-472f-A0FF-E1416B8B2E3A}"
HKCU\SearchScopes\{012E1000-F331-11DB-8314-0800200C9A66} - http://www.google.com/search?q={searchTerms}
HKCU\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} - http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IESR02
==== Reset Google Chrome ======================
C:\Users\Zagi\AppData\Local\Google\Chrome\User Data\Default\Preferences was reset successfully
C:\Users\Zagi\AppData\Local\Google\Chrome\User Data\Default\Secure Preferences was reset successfully
C:\Users\Zagi\AppData\Local\Microsoft\Edge\User Data\Default\Preferences was reset successfully
C:\Users\Zagi\AppData\Local\Microsoft\Edge\User Data\Default\Secure Preferences was reset successfully
C:\Users\Zagi\AppData\Local\Google\Chrome\User Data\Default\Web Data was reset successfully
C:\Users\Zagi\AppData\Local\Google\Chrome\User Data\Default\Web Data-journal was reset successfully
C:\Users\Zagi\AppData\Local\Microsoft\Edge\User Data\Default\Web Data was reset successfully
C:\Users\Zagi\AppData\Local\Microsoft\Edge\User Data\Default\Web Data-journal was reset successfully
==== Empty IE Cache ======================
C:\WINDOWS\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Users\Zagi\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\WINDOWS\sysWoW64\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\WINDOWS\sysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\Users\Zagi\AppData\Local\Microsoft\Windows\INetCache\IE emptied successfully
C:\WINDOWS\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\IE emptied successfully
C:\WINDOWS\sysWoW64\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\IE emptied successfully
==== Empty FireFox Cache ======================
No FireFox Profiles found
==== Empty Edge Cache ======================
Edge Cache Emptied Successfully
==== Empty Chrome Cache ======================
C:\Users\Zagi\AppData\Local\Google\Chrome\User Data\Default\Cache emptied successfully
C:\Users\Zagi\AppData\Local\Microsoft\Edge\User Data\Default\Cache emptied successfully
==== Empty All Flash Cache ======================
No Flash Cache Found
==== Empty All Java Cache ======================
No Java Cache Found
==== C:\zoek_backup content ======================
C:\zoek_backup (files=266 folders=1074 136936557 bytes)
==== Empty Temp Folders ======================
C:\Users\Default\AppData\Local\Temp emptied successfully
C:\Users\Default User\AppData\Local\Temp emptied successfully
C:\Users\defaultuser0\AppData\Local\Temp emptied successfully
C:\Users\Zagi\AppData\Local\Temp will be emptied at reboot
C:\WINDOWS\serviceprofiles\networkservice\AppData\Local\Temp emptied successfully
C:\WINDOWS\serviceprofiles\Localservice\AppData\Local\Temp emptied successfully
C:\WINDOWS\Temp will be emptied at reboot
==== After Reboot ======================
C:\WINDOWS\Temp successfully emptied
C:\Users\Zagi\AppData\Local\Temp successfully emptied
==== Empty Recycle Bin ======================
C:\$RECYCLE.BIN successfully emptied
==== Deleting Files / Folders ======================
==== EOF on 13.01.2021 at 0:06:58,50 ======================
Old Values:
New Values:
No Java Cache Found
- Level 2.5
Informace o kontroly
Název produktu : Zemana AntiMalware
Stav kontroly : Dokončena
Datum kontroly : 13.01.2021 0:18:05
Typ kontroly : Inteligentní kontrola
Čas trvání : 00:00:12
Zkontrolované objekty : 1844
Zjištěné objekty : 0
Vyloučené objekty : 0
Automatické odesílání : Ne
Operační systém : Windows 10 x64
Procesor : 4X Intel(R) Pentium(R) CPU G4560 @ 3.50GHz
Režim systému BIOS : UEFI
Informace o doméně : WORKGROUP,False,NetSetupWorkgroupName
CUID : 12C27D1A0567386849EF68
- Level 2.5
Logfile of Trend Micro HijackThis v2.0.5
Scan saved at 0:25:51, on 13.01.2021
MSIE: Internet Explorer v11.0 (11.00.19041.0001)
Boot mode: Normal
Running processes:
H:\Programy\VirtualCloneDrive\VCDDaemon.exe
C:\WINDOWS\SysWOW64\DllHost.exe
I:\Filmy\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/p/?LinkId=255141
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe
O1 - Hosts: ::1 localhost
O2 - BHO: IEToEdge BHO - {1FD49718-1D00-4B19-AF5F-070AF6D5D54C} - C:\Program Files (x86)\Microsoft\Edge\Application\87.0.664.75\BHO\ie_to_edge_bho.dll
O2 - BHO: Lync Click to Call BHO - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O2 - BHO: Java(tm) Plug-In SSV Helper - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files (x86)\Java\jre1.8.0_131\bin\ssv.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\Program Files (x86)\Microsoft Office\Office15\URLREDIR.DLL
O2 - BHO: Microsoft SkyDrive Pro Browser Helper - {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} - C:\Program Files (x86)\Microsoft Office\Office15\GROOVEEX.DLL
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files (x86)\Java\jre1.8.0_131\bin\jp2ssv.dll
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
O4 - HKLM\..\Run: [Autodesk Desktop App] "C:\Program Files (x86)\Autodesk\Autodesk Desktop App\AutodeskDesktopApp.exe" -tray
O4 - HKLM\..\Run: [VirtualCloneDrive] "H:\Programy\VirtualCloneDrive\VCDDaemon.exe" /s
O4 - HKLM\..\Run: [Command Center] C:\Program Files (x86)\MSI\Command Center\StartCommandCenter.exe
O4 - HKLM\..\Run: [Live Update] C:\Program Files (x86)\MSI\Live Update\Live Update.exe /REMINDER
O4 - HKCU\..\Run: [Steam] "C:\Steam\steam.exe" -silent
O4 - HKCU\..\Run: [CCleaner Smart Cleaning] "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
O4 - HKUS\S-1-5-19\..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [OneDriveSetup] C:\Windows\SysWOW64\OneDriveSetup.exe /thfirstsetup (User 'NETWORK SERVICE')
O8 - Extra context menu item: E&xportovat do Microsoft Excelu - res://C:\PROGRA~1\MICROS~1\Office15\EXCEL.EXE/3000
O8 - Extra context menu item: Od&eslat do OneNotu - res://C:\PROGRA~1\MICROS~1\Office15\ONBttnIE.dll/105
O9 - Extra button: Odeslat do OneNotu - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Od&eslat do OneNotu - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIE.dll
O9 - Extra button: Volání kliknutím v Lyncu - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O9 - Extra 'Tools' menuitem: Volání kliknutím v Lyncu - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O9 - Extra button: P&ropojené poznámky aplikace OneNote - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: P&ropojené poznámky aplikace OneNote - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIELinkedNotes.dll
O18 - Protocol: osf - {D924BDC6-C83A-4BD5-90D0-095128A113D1} - C:\Program Files (x86)\Microsoft Office\Office15\MSOSB.DLL
O18 - Filter hijack: text/xml - {807583E5-5146-11D5-A672-00B0D022E945} - C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\MSOXMLMF.DLL
O23 - Service: Autodesk Desktop App Service (AdAppMgrSvc) - Autodesk Inc. - C:\Program Files (x86)\Autodesk\Autodesk Desktop App\AdAppMgrSvc.exe
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) - Adobe Inc. - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: Intel® SGX AESM (AESMService) - Intel Corporation - C:\WINDOWS\System32\DriverStore\FileRepository\sgx_psw.inf_amd64_fafb1d329fdfe2c6\aesm_service.exe
O23 - Service: AMD Crash Defender Service - Unknown owner - C:\WINDOWS\system32\amdfendrsr.exe (file missing)
O23 - Service: AMD External Events Utility - AMD - C:\WINDOWS\System32\DriverStore\FileRepository\u0361132.inf_amd64_4863ccf4c1b997c9\B361196\atiesrxx.exe
O23 - Service: Alcohol Virtual Drive Auto-mount Service (AxAutoMntSrv) - Alcohol Soft Development Team - H:\Programy\Alcohol 120\AxAutoMntSrv.exe
O23 - Service: Alcohol Virtual AHCI Controller Management Service (AxVirtualAHCISrv) - Alcohol Soft Development Team - H:\Programy\Alcohol 120\AxAHCIServiceEx.exe
O23 - Service: @%SystemRoot%\system32\CredentialEnrollmentManager.exe,-100 (CredentialEnrollmentManagerUserSvc) - Unknown owner - C:\WINDOWS\system32\CredentialEnrollmentManager.exe (file missing)
O23 - Service: CredentialEnrollmentManagerUserSvc_4550f - Unknown owner - C:\WINDOWS\system32\CredentialEnrollmentManager.exe (file missing)
O23 - Service: @%SystemRoot%\system32\DeveloperToolsSvc.exe,-100 (DeveloperToolsService) - Unknown owner - C:\WINDOWS\System32\DeveloperToolsSvc.exe (file missing)
O23 - Service: SCP DS3 Service (Ds3Service) - Scarlet.Crush Productions - I:\Filmy\ps3 controller\ScpServer\bin\ScpService.exe
O23 - Service: FLEXnet Licensing Service 64 - Flexera Software LLC - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe
O23 - Service: Google Chrome Elevation Service (GoogleChromeElevationService) - Google LLC - C:\Program Files (x86)\Google\Chrome\Application\87.0.4280.141\elevation_service.exe
O23 - Service: Služba Aktualizace Google (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Služba Aktualizace Google (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Intel(R) Capability Licensing Service TCP IP Interface - Intel(R) Corporation - C:\Program Files\Intel\iCLS Client\SocketHeciServer.exe
O23 - Service: Intel(R) Online Connect - Intel Corporation - C:\Program Files\Intel\Intel(R) Online Connect\ioc.exe
O23 - Service: Intel(R) Online Connect Helper - Intel Corporation - C:\Program Files\Intel\Intel(R) Online Connect\iocHelperService.exe
O23 - Service: Intel(R) Online Connect Software Asset Manager - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Online Connect Access\Intel(R) Software Asset Manager\bin\IntelSoftwareAssetManagerService.exe
O23 - Service: Intel(R) PROSet Monitoring Service - Unknown owner - C:\Windows\system32\IProsetMonitor.exe (file missing)
O23 - Service: Intel(R) Online Connect Access Legacy CS Loader (Intel(R) TechnologyAccessLegacyCSLoader) - Intel(R) Corporation - C:\Program Files\Intel\Intel(R) Online Connect Access\LegacyCsLoaderService.exe
O23 - Service: Intel(R) Online Connect Access (Intel(R) TechnologyAccessService) - Intel(R) Corporation - C:\Program Files\Intel\Intel(R) Online Connect Access\IntelTechnologyAccessService.exe
O23 - Service: Intel(R) TPM Provisioning Service - Intel(R) Corporation - C:\Program Files\Intel\iCLS Client\TPMProvisioningService.exe
O23 - Service: Intel(R) Dynamic Application Loader Host Interface Service (jhi_service) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: Malwarebytes Service (MBAMService) - Malwarebytes - C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
O23 - Service: MSI Command Center Clock Service (MSIClock_CC) - MSI - C:\Program Files (x86)\MSI\Command Center\ClockGen\MSIClockService_x64.exe
O23 - Service: MSI Command Center Comm Service (MSICOMM_CC) - MSI - C:\Program Files (x86)\MSI\Command Center\MSICommService.exe
O23 - Service: MSI Command Center CPU Service (MSICPU_CC) - MSI - C:\Program Files (x86)\MSI\Command Center\CPU\MSICPUService_x64.exe
O23 - Service: MSI Command Center Control Service (MSICTL_CC) - MSI - C:\Program Files (x86)\MSI\Command Center\MSIControlService.exe
O23 - Service: MSI Command Center DDR Service (MSIDDR_CC) - MSI - C:\Program Files (x86)\MSI\Command Center\DDR\MSIDDRService.exe
O23 - Service: MSI Command Center SMBus Service (MSISMB_CC) - MSI - C:\Program Files (x86)\MSI\Command Center\SMBus\MSISMBService.exe
O23 - Service: MSI Command Center SuperIO Service (MSISuperIO_CC) - MSI - C:\Program Files (x86)\MSI\Command Center\SuperIO\MSISuperIOService.exe
O23 - Service: MSI Live Update Service (MSI_LiveUpdate_Service) - Micro-Star INT'L CO., LTD. - C:\Program Files (x86)\MSI\Live Update\MSI_LiveUpdate_Service.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\WINDOWS\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\PerceptionSimulation\PerceptionSimulationService.exe,-101 (perceptionsimulation) - Unknown owner - C:\WINDOWS\system32\PerceptionSimulation\PerceptionSimulationService.exe (file missing)
O23 - Service: RogueKiller RTP (rkrtservice) - Unknown owner - C:\Program Files\RogueKiller\RogueKillerSvc.exe
O23 - Service: @%systemroot%\system32\SecurityHealthAgent.dll,-1002 (SecurityHealthService) - Unknown owner - C:\WINDOWS\system32\SecurityHealthService.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Defender Advanced Threat Protection\MsSense.exe,-1001 (Sense) - Unknown owner - C:\Program Files (x86)\Windows Defender Advanced Threat Protection\MsSense.exe (file missing)
O23 - Service: @%SystemRoot%\System32\SgrmBroker.exe,-100 (SgrmBroker) - Unknown owner - C:\WINDOWS\system32\SgrmBroker.exe (file missing)
O23 - Service: @firewallapi.dll,-50323 (SNMPTRAP) - Unknown owner - C:\WINDOWS\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spectrum.exe,-101 (spectrum) - Unknown owner - C:\WINDOWS\system32\spectrum.exe (file missing)
O23 - Service: OpenSSH SSH Server (sshd) - Unknown owner - C:\WINDOWS\System32\OpenSSH\sshd.exe (file missing)
O23 - Service: StarWind AE Service (StarWindServiceAE) - StarWind Software - H:\Programy\Alcohol 120\StarWind\StarWindServiceAE.exe
O23 - Service: ZAM Controller Service (ZAMSvc) - Copyright 2017. - H:\Programy\Zemana AntiMalware\ZAM.exe
End of file - 14372 bytes
Boot mode: Normal
Running processes:
- člen Security týmu
Zavři ostatní aplikace a prohlížeče, odpoj se od netu a fixni v HJT:
Návod
Co problémy?
Návod
Kód: Vybrat vše
Co problémy?
- Level 2.5
Hotovo. Těžko říct, zatím se to neobjevilo, ale nebylo to pravidlem ani předtím. Dám vědět v příštích dnech co a jak. Prozatím moc děkuji.
OK.
- Level 2.5
Tak se mi to dneska stalo zase. Doteď jsem si myslel, že vše běží normálně, až na ty monitory. Ale klávesnice sice svítí, akorát nereaguje (např. NumLock, CapsLock a tak).
Stáhni si Memtest
http://www.stahuj.cz/utility_a_ostatni/ ... i/memtest/
Políčko , ve kterém je napsáno:
All unused RAM ponech.
-dej Start , nech nejméně 2h běžet , pokud bude po 2h stále 0 errors , jsou v pořádku.
V případě vyšších kapacit RAM je třeba Memtest spustit několikrát , pro 2GB ( jednotlivá největší kapacita RAM) 2x , pro 4GB 3x , pro 8Gb 4x ap.
poklepej na Memtest , pak znovu a znovu , do políček všech Memtestů napiš 2048 , pak dej u všech Memtestů "Start".
Ještě zkontrolovat HDD na chyby ,popř. zkusit jeho defragmentaci ..
Stáhni si CrystalDiskInfo
https://www.stahuj.cz/utility_a_ostatni ... ldiskinfo/
Spusť program a klikni na Úpravy-Kopírovat. Poté sem vlož pomocí Ctrl+V obsah logu.
- Level 2.5
Ahoj, nějakou dobu jsem nebyl na PC. Dnes jsem to zapl až na čtvrtý pokus, takže problémy přetrvávají.
MemTest, jestli jsem pochopil správně, tak jsem zapnul 8 x po 2048 přes 2h a 0 errorů
CrystalDiskInfo 8.10.0 (C) 2008-2021 hiyohiyo
Crystal Dew World: https://crystalmark.info/
OS : Windows 10 Professional [10.0 Build 19041] (x64)
Date : 2021/01/26 22:14:25
- Standardní řadič SATA AHCI [ATA]
+ Standardní řadič SATA AHCI [ATA]
- ST1000DM010-2EP102
- KINGSTON SUV400S37120G
- CT500MX500SSD4
- Obecné silo testů IEEE 1667
- Silo úložiště Microsoft TCG
- Generic IEEE 1667 ACT
+ Virtual CloneDrive [SCSI]
- ELBY CLONEDRIVE SCSI CdRom Device
(01) ST1000DM010-2EP102 : 1000,2 GB [0/0/0, pd1]
(02) KINGSTON SUV400S37120G : 120,0 GB [1/0/0, pd1] - ki
(03) CT500MX500SSD4 : 500,1 GB [2/0/0, pd1] - m2
Model : ST1000DM010-2EP102
Firmware : CC43
Serial Number : W9A879HS
Disk Size : 1000,2 GB (8,4/137,4/1000,2/1000,2)
Buffer Size : Neznámy údaj
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
Power On Hours : 5742 hod.
Power On Count : 1676 krát
Temperature : 28 C (82 F)
Health Status : Dobrý
Features : S.M.A.R.T., APM, NCQ
APM Level : 8080h [ON]
AAM Level : ----
Drive Letter : H: I:
01 _66 _63 __6 0000004C0F81 Počet chyb čtení
03 _97 _96 __0 000000000000 Čas na roztočení ploten
04 _96 _96 _20 0000000012D8 Počet spuštění/zastavení
05 100 100 _10 000000000000 Počet přemapovaných sektorů
07 _72 _58 _45 00020266C9C3 Počet chybných hledání
09 _94 _94 __0 00000000166E Hodin v činnosti
0C _99 _99 _20 00000000068C Počet cyklů zapnutí zařízení
B7 100 100 __0 000000000000 Specifický pro výrobce
B8 100 100 _99 000000000000 Ukončovacích chyb
BB 100 100 __0 000000000000 Ohlášeno neopravitelných chyb
BC 100 100 __0 000000000000 Časový limit příkazu
BD 100 100 __0 000000000000 Vysoká rychlost zápisu
BE _72 _65 _40 00001C16001C Teplota toku vzduchu
C1 _98 _98 __0 0000000012EF Počet cyklů načítání/vymazání
C2 _28 _15 __0 000F0000001C Teplota
C3 __1 __1 __0 0000004C0F81 Počet oprav chybného čtení
F0 100 253 __0 97A6000012C6 Čas nastavování hlaviček - v hodinách
F1 100 253 __0 0002BCB5D88F Total Host Writes
F2 100 253 __0 0004DD5A1E74 Total Host Reads
0 1 2 3 4 5 6 7 8 9
010: 2020 2020 2020 2020 2020 2020 5739 4138 3739 4853
020: 0000 0000 0000 4343 3433 2020 2020 5354 3130 3030
030: 444D 3031 302D 3245 5031 3032 2020 2020 2020 2020
070: 0000 0000 0000 0000 0000 001F 850E 0006 00CC 0040
080: 01F0 0029 346B 7D69 4163 3469 BC49 4163 207F 0034
090: 0034 8080 FFFE 0000 D0D0 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5000 C500
110: AAEA 2802 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 6DB0
130: 7470 6DB0 7470 2020 0002 0140 0100 5000 3C06 3C0A
140: 0000 003C 0000 0008 0000 0000 FDFF 0280 0000 0000
150: 0008 0000 0000 0000 0000 8000 0000 0184 9400 8000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
200: 0000 0000 0000 0000 0000 0000 1085 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 1020 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 23A5
000: 0A 00 01 0F 00 42 3F 81 0F 4C 00 00 00 00 03 03
010: 00 61 60 00 00 00 00 00 00 00 04 32 00 60 60 D8
020: 12 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00
030: 00 00 07 0F 00 48 3A C3 C9 66 02 02 00 00 09 32
040: 00 5E 5E 6E 16 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0C 32 00 63 63 8C 06 00 00 00
060: 00 00 B7 32 00 64 64 00 00 00 00 00 00 00 B8 32
070: 00 64 64 00 00 00 00 00 00 00 BB 32 00 64 64 00
080: 00 00 00 00 00 00 BC 32 00 64 64 00 00 00 00 00
090: 00 00 BD 3A 00 64 64 00 00 00 00 00 00 00 BE 22
0A0: 00 48 41 1C 00 16 1C 00 00 00 C1 32 00 62 62 EF
0B0: 12 00 00 00 00 00 C2 22 00 1C 0F 1C 00 00 00 0F
0C0: 00 00 C3 1A 00 01 01 81 0F 4C 00 00 00 00 C5 12
0D0: 00 64 64 00 00 00 00 00 00 00 C6 10 00 64 64 00
0E0: 00 00 00 00 00 00 C7 3E 00 C8 C8 00 00 00 00 00
0F0: 00 00 F0 00 00 64 FD C6 12 00 00 A6 97 0A F1 00
100: 00 64 FD 8F D8 B5 BC 02 00 00 F2 00 00 64 FD 74
110: 1E 5A DD 04 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 73
170: 03 00 01 00 01 67 02 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 07 03 03 03 03 03 03 03
190: 03 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 10 55 58 5A CD 12 00 00
1B0: 00 00 00 00 01 00 24 01 8F D8 B5 BC 02 00 00 00
1C0: 74 1E 5A DD 04 00 00 00 00 00 00 00 AD 26 77 00
1D0: 00 00 00 00 00 00 00 00 E3 01 00 00 06 00 00 00
1E0: 00 00 00 00 2D 00 00 00 00 00 00 00 00 00 00 06
1F0: 00 00 00 00 00 00 00 00 00 00 14 17 00 00 00 89
000: 01 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00
020: 00 00 00 00 00 00 05 0A 00 00 00 00 00 00 00 00
030: 00 00 07 2D 00 00 00 00 00 00 00 00 00 00 09 00
060: 00 00 B7 00 00 00 00 00 00 00 00 00 00 00 B8 63
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00
080: 00 00 00 00 00 00 BC 00 00 00 00 00 00 00 00 00
090: 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 BE 28
0A0: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
0B0: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
0C0: 00 00 C3 00 00 00 00 00 00 00 00 00 00 00 C5 00
0D0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0E0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0F0: 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 F1 00
100: 00 00 00 00 00 00 00 00 00 00 F2 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AF
Model : KINGSTON SUV400S37120G
Firmware : 0C3J96R9
Serial Number : 50026B776A048D53
Disk Size : 120,0 GB (8,4/120,0/120,0/120,0)
Queue Depth : 32
# of Sectors : 234441648
Rotation Rate : ---- (SSD)
Major Version : ACS-4
Minor Version : ATA8-ACS version 6
Power On Hours : 8263 hod.
Power On Count : 2156 krát
Host Reads : 10337 GB
Host Writes : 8869 GB
NAND Writes : 4022 GB
Temperature : 30 C (86 F)
Health Status : Dobrý (88 %)
Features : S.M.A.R.T., APM, NCQ, TRIM
APM Level : 0000h [OFF]
AAM Level : ----
Drive Letter : C:
01 100 100 __0 00000000020D Read Error Rate
05 100 100 _10 000000000000 Reallocated Sector Count
09 100 100 __0 000000002047 Power On Hours
0C 100 100 __0 00000000086C Power Cycle Count
64 100 100 __0 0000006B5310 Specifický pro výrobce
65 100 100 __0 0000000AD040 Specifický pro výrobce
AA 100 100 __0 000000000000 Used Reserved Block Count
AB 100 100 __0 000000000000 Program Fail Count
AC 100 100 __0 000000000000 Erase Fail Count
AE 100 100 __0 000000000037 Unexpected Power Off Count
AF 100 100 __0 000000000000 Program Fail Count Worst Die
B0 100 100 __0 000000000000 Erase Fail Count Worst Die
B1 _88 _88 __0 000000001033 Wear Leveling Count
B2 100 100 __0 000000000000 Used Reserved Block Count worst Die
B4 100 100 __0 0000000002C1 Unused Reserved Block Count (SSD Total)
B7 _95 _95 __0 000000000021 Specifický pro výrobce
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
C2 _30 100 __0 00240010001E Temperature
C3 100 100 __0 00000000020D On-the-Fly ECC Error Count
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Pending Sector Count
C7 100 100 __0 000000000000 UDMA CRC Error Count
C9 100 100 __0 000000000000 Uncorrectable Read Error Rate
CC 100 100 __0 00000000020D Soft ECC Correction Rate
E7 _88 _88 __0 00000000000C SSD Life Left
E9 100 100 __0 00000000318E Specifický pro výrobce
EA 100 100 __0 000000000FB6 Lifetime Nand Writes
F1 100 100 __0 0000000022A5 Lifetime Host Writes
F2 100 100 __0 000000002861 Lifetime Host Reads
FA 100 100 __0 000000000241 Total Number of NAND Read Retries
0 1 2 3 4 5 6 7 8 9
010: 3530 3032 3642 3737 3641 3034 3844 3533 2020 2020
020: 0000 0000 0000 3043 334A 3936 5239 4B49 4E47 5354
030: 4F4E 2053 5556 3430 3053 3337 3132 3047 2020 2020
050: 4000 0000 0000 0007 3FFF 0010 003F FC10 00FB B910
060: 4BB0 0DF9 0000 0007 0003 0078 0078 0078 0078 4D18
070: 0000 0000 0000 0000 0000 001F E70E 0006 00CC 0040
080: 0FFE 0028 746B 7409 4163 7069 B401 4167 207F 0002
090: 0002 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 4BB0 0DF9 0000 0000 0000 0008 6003 0000 0550 3804
110: 4001 0000 0000 0000 0000 0000 0000 0000 0000 4358
120: 4018 0000 0000 0000 0000 0000 0000 0000 0029 4D52
130: 564C 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 3933 3539 2020 2020 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0007 0001
170: 2020 2020 2020 2020 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 107F 0051 0000 0000 0000 0000 0000 0000
230: 4BB0 0DF9 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 83A5
000: 30 00 01 2F 00 64 64 0D 02 00 00 00 00 00 05 33
010: 00 64 64 00 00 00 00 00 00 0A 09 32 00 64 64 47
020: 20 00 00 00 00 00 0C 32 00 64 64 6C 08 00 00 00
030: 00 00 64 32 00 64 64 10 53 6B 00 00 00 00 65 32
040: 00 64 64 40 D0 0A 00 00 00 00 AA 32 00 64 64 00
050: 00 00 00 00 00 00 AB 32 00 64 64 00 00 00 00 00
060: 00 00 AC 32 00 64 64 00 00 00 00 00 00 00 AE 32
070: 00 64 64 37 00 00 00 00 00 00 AF 32 00 64 64 00
080: 00 00 00 00 00 00 B0 32 00 64 64 00 00 00 00 00
090: 00 00 B1 32 00 58 58 33 10 00 00 00 00 00 B2 02
0A0: 00 64 64 00 00 00 00 00 00 00 B4 02 00 64 64 C1
0B0: 02 00 00 00 00 00 B7 32 00 5F 5F 21 00 00 00 00
0C0: 00 00 BB 33 00 64 64 00 00 00 00 00 00 00 C2 22
0D0: 00 1E 64 1E 00 10 00 24 00 00 C3 32 00 64 64 0D
0E0: 02 00 00 00 00 00 C4 32 00 64 64 00 00 00 00 00
0F0: 00 00 C5 32 00 64 64 00 00 00 00 00 00 00 C7 12
100: 00 64 64 00 00 00 00 00 00 00 C9 32 00 64 64 00
110: 00 00 00 00 00 00 CC 32 00 64 64 0D 02 00 00 00
120: 00 00 E7 32 00 58 58 0C 00 00 00 00 00 00 E9 32
130: 00 64 64 8E 31 00 00 00 00 00 EA 32 00 64 64 B6
140: 0F 00 00 00 00 00 F1 32 00 64 64 A5 22 00 00 00
150: 00 00 F2 32 00 64 64 61 28 00 00 00 00 00 FA 32
160: 00 64 64 41 02 00 00 00 00 00 00 00 05 00 01 71
170: 03 00 01 00 02 05 00 00 00 00 00 00 00 00 00 00
180: 00 00 5F 00 00 00 00 00 00 00 00 00 5F 00 00 00
190: 00 00 00 00 00 00 00 00 8C 38 00 00 00 00 00 00
1A0: B7 BA B3 54 04 00 00 00 00 80 DA 3E 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 16 48 22 0C 05 00 00 00
1C0: C0 E4 CB F2 00 00 00 00 C1 02 00 00 03 00 00 00
1D0: 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: FB 94 01 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 04 08 00 00 00 00 00 DB
000: 04 00 01 00 00 00 00 00 00 00 00 00 00 00 05 0A
010: 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00
020: 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00
030: 00 00 64 00 00 00 00 00 00 00 00 00 00 00 65 00
040: 00 00 00 00 00 00 00 00 00 00 AA 00 00 00 00 00
050: 00 00 00 00 00 00 AB 00 00 00 00 00 00 00 00 00
060: 00 00 AC 00 00 00 00 00 00 00 00 00 00 00 AE 00
070: 00 00 00 00 00 00 00 00 00 00 AF 00 00 00 00 00
080: 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00
090: 00 00 B1 00 00 00 00 00 00 00 00 00 00 00 B2 00
0A0: 00 00 00 00 00 00 00 00 00 00 B4 00 00 00 00 00
0B0: 00 00 00 00 00 00 B7 00 00 00 00 00 00 00 00 00
0C0: 00 00 BB 00 00 00 00 00 00 00 00 00 00 00 C2 00
0D0: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00
0E0: 00 00 00 00 00 00 C4 00 00 00 00 00 00 00 00 00
0F0: 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 C7 00
100: 00 00 00 00 00 00 00 00 00 00 C9 00 00 00 00 00
110: 00 00 00 00 00 00 CC 00 00 00 00 00 00 00 00 00
120: 00 00 E7 00 00 00 00 00 00 00 00 00 00 00 E9 00
130: 00 00 00 00 00 00 00 00 00 00 EA 00 00 00 00 00
140: 00 00 00 00 00 00 F1 00 00 00 00 00 00 00 00 00
150: 00 00 F2 00 00 00 00 00 00 00 00 00 00 00 FA 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 76
(03) CT500MX500SSD4
Model : CT500MX500SSD4
Firmware : M3CR023
Serial Number : 1849E1DC5C3F
Disk Size : 500,1 GB (8,4/137,4/500,1/500,1)
Queue Depth : 32
# of Sectors : 976773168
Major Version : ACS-3
Minor Version : ACS-3 Revision 5
Power On Hours : 4155 hod.
Power On Count : 1126 krát
Host Writes : 2897 GB
Temperature : 50 C (122 F)
Health Status : Dobrý (99 %)
Features : S.M.A.R.T., APM, NCQ, TRIM, DevSleep
APM Level : 00FEh [ON]
AAM Level : ----
Drive Letter : D:
01 100 100 __0 000000000000 Raw Read Error Rate
05 100 100 _10 000000000000 Reallocated Sectors Count
09 100 100 __0 00000000103B Power-On Hours
0C 100 100 __0 000000000466 Power Cycle Count
AD _99 _99 __0 000000000013 Average Block-Erase Count
AE 100 100 __0 00000000000D Unexpected Power Loss Count
B4 __0 __0 __0 000000000020 Unused Reserve NAND Blocks
B7 100 100 __0 000000000000 SATA Interface Downshift
B8 100 100 __0 000000000000 Error Correction Count
C2 _50 _10 __0 005A00000032 Temperature
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Smart Off-line Scan Uncorrectable Error Count
C7 100 100 __0 000000000000 Ultra DMA CRC Error Rate
CA _99 _99 __1 000000000001 Percent Lifetime Used
CE 100 100 __0 000000000000 Write Error Rate
D2 100 100 __0 000000000000 Successful RAIN Recovery Count
F6 100 100 __0 00016A37658E Total Host Sector Writes
F7 100 100 __0 000005DD2832 Host Program Page Count
F8 100 100 __0 00000479FDC5 Background Program Page Count
0 1 2 3 4 5 6 7 8 9
010: 3138 3439 4531 4443 3543 3346 2020 2020 2020 2020
020: 0000 0000 0000 4D33 4352 3032 3320 4354 3530 304D
030: 5835 3030 5353 4434 2020 2020 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8001 4001 2F00
050: 4001 0000 0000 0006 3FFF 0010 003F FC10 00FB BD01
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0D98
070: 0000 0000 0000 0000 0000 001F 850E 0086 014C 0040
080: 07F0 006D 7069 7409 4163 7069 B409 4163 207F 0000
090: 0000 00FE 0000 0000 0000 0000 0000 0000 0000 0000
100: 6030 3A38 0000 0000 0000 0008 4000 0000 500A 0751
110: E1DC 5C3F 0000 0000 0000 0000 0000 0000 0000 411C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0000 4372
130: 7563 6961 6C00 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 0031 0000 0000 4000
220: 0000 0000 11FF 0000 0000 0000 0000 0000 0000 0000
230: 6030 3A38 0000 0000 0001 0200 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 BFA5
000: 10 00 01 2F 00 64 64 00 00 00 00 00 00 00 05 32
010: 00 64 64 00 00 00 00 00 00 00 09 32 00 64 64 3B
020: 10 00 00 00 00 00 0C 32 00 64 64 66 04 00 00 00
030: 00 00 AB 32 00 64 64 00 00 00 00 00 00 00 AC 32
040: 00 64 64 00 00 00 00 00 00 00 AD 32 00 63 63 13
050: 00 00 00 00 00 00 AE 32 00 64 64 0D 00 00 00 00
060: 00 00 B4 33 00 00 00 20 00 00 00 00 00 00 B7 32
070: 00 64 64 00 00 00 00 00 00 00 B8 32 00 64 64 00
080: 00 00 00 00 00 00 BB 32 00 64 64 00 00 00 00 00
090: 00 00 C2 22 00 32 0A 32 00 00 00 5A 00 00 C4 32
0A0: 00 64 64 00 00 00 00 00 00 00 C5 32 00 64 64 00
0B0: 00 00 00 00 00 00 C6 30 00 64 64 00 00 00 00 00
0C0: 00 00 C7 32 00 64 64 00 00 00 00 00 00 00 CA 30
0D0: 00 63 63 01 00 00 00 00 00 00 CE 0E 00 64 64 00
0E0: 00 00 00 00 00 00 D2 32 00 64 64 00 00 00 00 00
0F0: 00 00 F6 32 00 64 64 8E 65 37 6A 01 00 00 F7 32
100: 00 64 64 32 28 DD 05 00 00 00 F8 32 00 64 64 C5
110: FD 79 04 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 7B
170: 03 00 01 00 02 1E 02 00 00 00 00 00 00 00 00 00
180: 00 00 4D 33 43 52 30 32 33 20 00 00 00 00 00 00
190: 53 4D 32 32 35 38 42 31 36 41 52 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10
000: 01 00 01 00 00 00 00 00 00 00 00 00 00 00 05 0A
030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00
040: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00
050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00
060: 00 00 B4 00 00 00 00 00 00 00 00 00 00 00 B7 00
070: 00 00 00 00 00 00 00 00 00 00 B8 00 00 00 00 00
080: 00 00 00 00 00 00 BB 00 00 00 00 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C4 00
0A0: 00 00 00 00 00 00 00 00 00 00 C5 00 00 00 00 00
0B0: 00 00 00 00 00 00 C6 00 00 00 00 00 00 00 00 00
0C0: 00 00 C7 00 00 00 00 00 00 00 00 00 00 00 CA 01
0D0: 00 00 00 00 00 00 00 00 00 00 CE 00 00 00 00 00
0E0: 00 00 00 00 00 00 D2 00 00 00 00 00 00 00 00 00
0F0: 00 00 F6 00 00 00 00 00 00 00 00 00 00 00 F7 00
100: 00 00 00 00 00 00 00 00 00 00 F8 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 22
- CT500MX500SSD4
Firmware : CC43
Queue Depth : 32
AAM Level : ----
0 1 2 3 4 5 6 7 8 9
Firmware : 0C3J96R9
Queue Depth : 32
AAM Level : ----
Drive Letter : C:
0 1 2 3 4 5 6 7 8 9
(03) CT500MX500SSD4
Firmware : M3CR023
Queue Depth : 32
AAM Level : ----
Drive Letter : D:
0 1 2 3 4 5 6 7 8 9
MB: MSI B250 PC MATE
CPU: Intel Pentium G4560
GPU: SAPPHIRE RX580 8GB NITRO+
RAM: 2x8GB Kingston HyperX Fury Black 8GB DDR4 2133MHz
PSU: Seasonic SS.500ET-T3-500W, Energy Knight
HDD: SAMSUNG HD103SJ ATA Device - 1TB
SSD: Kingston Now UV400 - 120GB
Case: SilentiumPC Regnum RG1 Pure Black
Re: Po zapnutí PC někdy neběží monitory
To vypadá spíš na napájení , zdroj., základní deska BIOS.. zkusil bych vyndat baterii na desce , při vypnutém stavu na 5min.
Stáhni si a nainstaluj WhoCrashed
otevři ho a klikni na Analyze.
Program vytvoří zprávu , zkopíruj celou a vlož prosím sem.
- Level 2.5
Omlouvám se za pomalé reakce, ale jak jsem normálně denně na PC, tak teď mi to párkrát nevyšlo. Baterie vyndána na 5 min a analýza provedena:
Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
On Fri 29.01.2021 20:54:48 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\012921-12515-01.dmp
This was probably caused by the following module: amdkmdag.sys (0xFFFFF800562F5040)
Bugcheck code: 0x116 (0xFFFFB40EA1D4D460, 0xFFFFF800562F5040, 0xFFFFFFFFC0000001, 0x3)
Error: VIDEO_TDR_ERROR
file path: C:\WINDOWS\System32\DriverStore\FileRepository\u0361132.inf_amd64_4863ccf4c1b997c9\B361196\amdkmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: amdkmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: amdkmdag.sys Advanced Micro Devices, Inc. VIDEO_TDR_ERROR
On Tue 26.01.2021 19:57:06 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\012621-8078-01.dmp
This was probably caused by the following module: amdkmdag.sys (0xFFFFF8016A925040)
Bugcheck code: 0x116 (0xFFFFB188073D5460, 0xFFFFF8016A925040, 0xFFFFFFFFC0000001, 0x3)
C:\WINDOWS
C:\WINDOWS\Minidump
Uživatelé prohlížející si toto fórum: petee.n a 2 hosti
