Logfile of Trend Micro HijackThis v2.0.5
Scan saved at 20:24:43, on 29.11.2022
MSIE: Internet Explorer v11.0 (11.00.9600.19541)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Kaspersky Lab\Kaspersky Password Manager 9.0.2\kpm_tray.exe
C:\Program Files (x86)\Kaspersky Lab\Kaspersky VPN 5.8\ksdeui.exe
C:\Users\Otto\Desktop\HijackThis.exe
C:\Windows\SysWOW64\DllHost.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
F2 - REG:system.ini: UserInit=userinit.exe,
O1 - Hosts: ::1 localhost
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
O4 - HKCU\..\Run: [CCleaner Smart Cleaning] "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
O4 - HKUS\S-1-5-18\..\Run: [GoogleDriveFS] C:\Program Files\Google\Drive File Stream\51.0.14.0\GoogleDriveFS.exe --startup_mode (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [GoogleDriveFS] C:\Program Files\Google\Drive File Stream\51.0.14.0\GoogleDriveFS.exe --startup_mode (User 'Default user')
O8 - Extra context menu item: E&xportovat do aplikace Microsoft Excel - res://C:\PROGRA~2\MICROS~1\Office12\EXCEL.EXE/3000
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~1\Office12\REFIEBAR.DLL
O17 - HKLM\System\CCS\Services\Tcpip\..\{0D0B23C0-6C35-474E-8175-7C25C02CFEA3}: NameServer = 198.51.100.1,198.51.100.2
O23 - Service: Acronis Nonstop Backup Service (afcdpsrv) - Acronis - C:\Program Files (x86)\Common Files\Acronis\CDP\afcdpsrv.exe
O23 - Service: Služba Kaspersky Anti-Virus 21.3 (AVP21.3) - AO Kaspersky Lab - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 21.3\avp.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: BrYNSvc - Brother Industries, Ltd. - C:\Program Files (x86)\Browny02\BrYNSvc.exe
O23 - Service: CCleaner Performance Optimizer Service (CCleanerPerformanceOptimizerService) - Piriform Software Ltd - C:\Program Files\CCleaner\CCleanerPerformanceOptimizerService.exe
O23 - Service: Google Chrome Elevation Service (GoogleChromeElevationService) (GoogleChromeElevationService) - Google LLC - C:\Program Files (x86)\Google\Chrome\Application\107.0.5304.122\elevation_service.exe
O23 - Service: Služba Aktualizace Google (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Služba Aktualizace Google (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: HuaweiHiSuiteService64.exe - Unknown owner - C:\Program Files (x86)\HiSuite\HandSetService\HuaweiHiSuiteService64.exe
O23 - Service: @%SystemRoot%\system32\ieetwcollectorres.dll,-1000 (IEEtwCollectorService) - Unknown owner - C:\Windows\system32\IEEtwCollector.exe (file missing)
O23 - Service: Kaspersky Volume Shadow Copy Service Bridge 21.3 (klvssbridge64_21.3) - AO Kaspersky Lab - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Internet Security 21.3\x64\vssbridge64.exe
O23 - Service: Kaspersky Password Manager Service (kpm_launch_service) - AO Kaspersky Lab - C:\Program Files (x86)\Kaspersky Lab\Kaspersky Password Manager 9.0.2\kpm_service.exe
O23 - Service: Služba Kaspersky VPN Secure Connection 5.8 (KSDE5. - AO Kaspersky Lab - C:\Program Files (x86)\Kaspersky Lab\Kaspersky VPN 5.8\ksde.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: NVIDIA Update Service Daemon (nvUpdatusService) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\daemonu.exe
End of file - 7111 bytes
Prosím o kontrolu logu
- jaro3
- člen Security týmu
Re: Prosím o kontrolu logu
Stáhni si ATF Cleaner
https://www.majorgeeks.com/mg/getmirror ... ner,2.html
Poklepej na ATF Cleaner.exe, klikni na select all, poté:
- Pokud používáš jen Google Chrome ,Edge , tak ATF nemusíš použít.
Stáhni si TFC
http://www.geekstogo.com/forum/files/fi ... -oldtimer/
Stáhni AdwCleaner (by Xplode)
http://www.bleepingcomputer.com/download/adwcleaner/
http://www.adlice.com/downloadprogress/
pro majitele win7 stáhni zde:
https://filehippo.com/download_adwcleaner/ ( nedávej aktualizaci!)
Ulož si ho na svojí plochu . Klikni na „Souhlasím“ k povrzení podmínek.
Spusť program poklepáním a klikni na „Skenování“
Po skenu se objeví log , který se otevře. ( jinak je uložen systémovem disku jako) C:\AdwCleaner\Logs, jeho obsah sem celý vlož.
https://www.malwarebytes.com/mwb-download/thankyou/
na plochu , nainstaluj a spusť ho
-Pokud není program aktuální , klikni na možnost „Aktualizovat nyní“ či „Opravit nyní“.
- bude nalezena aktualizace a nainstaluje se.
- poté klikni na Spustit skenování
- po proběhnutí skenu se ti objeví hláška vpravo dole, tak klikni na Zobrazit zprávu a vyber Export a vyber Kopírovat do schránky a vlož sem celý log. Nebo klikni na „Textový soubor ( .txt)“ a log si ulož.
-jinak se log nachází v programu po kliknutí na „Zprávy“ , nebo je uložen zde: C:\ProgramData\Malwarebytes\Malwarebytes Anti-Malware\Logs
- po té klikni na tlačítko Dokončit, a program zavři křížkem vpravo nahoře.
(zatím nic nemaž!).
Pokud budou problémy , spusť v nouz. režimu.
Problémy?
Stáhni si TFC
(zatím nic nemaž!).
Problémy?
Malwarebytes
-Podrobnosti logovacího souboru-
Datum skenování: 30.11.22
Čas skenování: 14:46
Logovací soubor: 53e1d63e-70b5-11ed-a50d-00ff0d0b23c0.json
-Informace o softwaru-
Verze: 4.5.18.226
Verze komponentů: 1.0.1823
Aktualizovat verzi balíku komponent: 1.0.62890
Licence: Zkušební
-Systémová informace-
OS: Windows 7 Service Pack 1
CPU: x64
Systém souborů: NTFS
Uživatel: Otto-PC\Otto
-Shrnutí skenování-
Typ skenování: Skenování hrozeb (Threat Scan)
Spuštění skenování: Ruční
Výsledek: Dokončeno
Skenované objekty: 266448
Zjištěné hrozby: 2
Hrozby umístěné do karantény: 0
Uplynulý čas: 32 min, 6 sek
-Možnosti skenování-
Paměť: Povoleno
Start: Povoleno
Systém souborů: Povoleno
Archivy: Povoleno
Rootkity: Zakázáno
Heuristika: Povoleno
Potenciálně nežádoucí program: Detekovat
Potenciálně nežádoucí modifikace: Detekovat
-Podrobnosti skenování-
Proces: 0
(Nebyly zjištěny žádné škodlivé položky)
Modul: 0
Klíč registru: 0
Hodnota v registru: 0
Data registrů: 0
Datové proudy: 0
Adresář: 0
Soubor: 2
HackTool.FilePatch, C:\PROGRAM FILES\4KDOWNLOAD\4KVIDEODOWNLOADER\PATCH.EXE, Žádná uživatelská akce, 7031, 281135, 1.0.62890, , ame, , 47B5E872F0AA9C1A5653495D921F07C2, C4CEB2C036628200A644592605E8FBC2B6A7B1046A2847D46DB5A2F2A589CC0A
Generic.Malware/Suspicious, C:\PROGRAM FILES (X86)\3DYD YOUTUBE SOURCE\X86\YTD.EXE, Žádná uživatelská akce, 0, 392686, 1.0.62890, , shuriken, , F74248F49E18B01A5A27B2C7B59D61D9, C12D8C8C2EED2776355FE1A2405BB7EAE7870592B1E3890F5D8F8DFAE0D0ABB9
Fyzický sektor: 0
WMI: 0
(end
TFC STRÁNKA NEFUNGUJE
Verze: 4.5.18.226
Licence: Zkušební
CPU: x64
-Shrnutí skenování-
Výsledek: Dokončeno
Zjištěné hrozby: 2
Paměť: Povoleno
Start: Povoleno
Archivy: Povoleno
Rootkity: Zakázáno
Proces: 0
Modul: 0
Klíč registru: 0
Data registrů: 0
Datové proudy: 0
Adresář: 0
Soubor: 2
Fyzický sektor: 0
WMI: 0
(end
- jaro3
ještě TFC , ATF A Adwcleaner.
. spusť znovu Malwarebytes' Anti-Malware a dej Skenovat nyní
- po proběhnutí programu se ti objeví hláška tak klikni na „Vše do karantény(smazat vybrané)“ a na „Exportovat záznam“ a vyber „textový soubor“ , soubor nějak pojmenuj a někam ho ulož. Zkopíruj se celý obsah toho logu.
# Malwarebytes AdwCleaner 8.4.0.0
# Build: 08-30-2022
# Database: 2022-10-10.1 (Cloud)
# Support: https://www.malwarebytes.com/support
# Mode: Scan
# Start: 12-02-2022
# Duration: 00:00:56
# OS: Windows 7 Service Pack 1
# Scanned: 32100
# Detected: 5
***** [ Services ] *****
No malicious services found.
***** [ Folders ] *****
PUP.Optional.Seznam.cz C:\Program Files (x86)\Seznam.cz
PUP.Optional.Seznam.cz C:\Users\Otto\AppData\Roaming\Seznam.cz
***** [ Files ] *****
No malicious files found.
***** [ DLL ] *****
No malicious DLLs found.
***** [ WMI ] *****
No malicious WMI found.
***** [ Shortcuts ] *****
No malicious shortcuts found.
***** [ Tasks ] *****
No malicious tasks found.
***** [ Registry ] *****
PUP.Optional.Seznam.cz HKCU\Software\Seznam.cz
***** [ Chromium (and derivatives) ] *****
PUP.Optional.Seznam.cz Seznam doplněk - Email - bgjpfhpjcgdppjbgnpnjllokbmcdllig
PUP.Optional.Seznam.cz Seznam doplněk - Esko - olfeabkoenfaoljndfecamgilllcpiak
***** [ Chromium URLs ] *****
No malicious Chromium URLs found.
***** [ Firefox (and derivatives) ] *****
No malicious Firefox entries found.
***** [ Firefox URLs ] *****
No malicious Firefox URLs found.
***** [ Hosts File Entries ] *****
No malicious hosts file entries found.
***** [ Preinstalled Software ] *****
No Preinstalled Software found.
AdwCleaner[S00].txt - [1681 octets] - [30/11/2022 14:38:42]
########## EOF - C:\AdwCleaner\Logs\AdwCleaner[S01].txt ##########
# Build: 08-30-2022
# Mode: Scan
# Start: 12-02-2022
# Scanned: 32100
# Detected: 5
***** [ DLL ] *****
***** [ WMI ] *****
TFC Download nejde stáhnout .Dostanu se na stránku a když dám stáhnout tak se objeví tato hláška.
ATF Jjsem nepoužil mám prohlížeč google chrome
Malwarebytes
Datum skenování: 02.12.22
Čas skenování: 8:36
Logovací soubor: 1292d68d-7214-11ed-8289-00ff0d0b23c0.json
Verze: 4.5.18.226
Aktualizovat verzi balíku komponent: 1.0.62896
Licence: Zkušební
CPU: x64
Uživatel: System
-Shrnutí skenování-
Spuštění skenování: Plánovač
Výsledek: Dokončeno
Skenované objekty: 266335
Zjištěné hrozby: 2
Hrozby umístěné do karantény: 2
Uplynulý čas: 1 hod, 7 min, 10 sek
Paměť: Povoleno
Start: Povoleno
Archivy: Povoleno
Rootkity: Zakázáno
Proces: 0
Modul: 0
Klíč registru: 0
Data registrů: 0
Datové proudy: 0
Adresář: 0
Soubor: 2
HackTool.FilePatch, C:\PROGRAM FILES\4KDOWNLOAD\4KVIDEODOWNLOADER\PATCH.EXE, V karanténě, 7031, 281135, 1.0.62896, , ame, , 47B5E872F0AA9C1A5653495D921F07C2, C4CEB2C036628200A644592605E8FBC2B6A7B1046A2847D46DB5A2F2A589CC0A
Generic.Malware/Suspicious, C:\PROGRAM FILES (X86)\3DYD YOUTUBE SOURCE\X86\YTD.EXE, V karanténě, 0, 392686, 1.0.62896, , shuriken, , F74248F49E18B01A5A27B2C7B59D61D9, C12D8C8C2EED2776355FE1A2405BB7EAE7870592B1E3890F5D8F8DFAE0D0ABB9
Fyzický sektor: 0
WMI: 0
(end)
Čas skenování: 8:36
Verze: 4.5.18.226
Licence: Zkušební
CPU: x64
Uživatel: System
-Shrnutí skenování-
Výsledek: Dokončeno
Zjištěné hrozby: 2
Paměť: Povoleno
Start: Povoleno
Archivy: Povoleno
Rootkity: Zakázáno
Proces: 0
Modul: 0
Klíč registru: 0
Data registrů: 0
Datové proudy: 0
Adresář: 0
Soubor: 2
Fyzický sektor: 0
WMI: 0
(end)
- jaro3
TFC jde normálně stáhnout , jen to píše nezabezpečeno. Zkus jiný prohlížeč.
Spusť znovu AdwCleaner (u Windows Vista či Windows7, klikni na AdwCleaner pravým a vyber „Spustit jako správce“
klikni na „Skenování“ , po prohledání klikni na „ do karantény“
Program provede opravu, po automatickém restartu klikni na Zobrazit logovací soubor“ a pak poklepej na odpovídají log, (C:\AdwCleaner [C?].txt) , jeho obsah sem celý vlož.
http://www.bleepingcomputer.com/downloa ... oval-tool/
https://downloads.malwarebytes.com/file/JRT-EOL
na svojí plochu.
Začne skenování programu. Skenování může trvat dlouho , podle množství nákaz. Po ukončení skenu se objeví log (JRT.txt) , který se uloží na ploše.
Sophos Virus Removal Tool je praktický softwarový nástroj, který by mohl odstranit infekce, které antivirový program nedetekuje .
Stáhněte si ho zde z některého odkazu:
https://www.majorgeeks.com/mg/getmirror ... ool,1.html
https://www.majorgeeks.com/mg/get/sopho ... ool,1.html
http://www.majorgeeks.com/mg/getmirror/ ... ool,1.html
http://www.majorgeeks.com/mg/getmirror/ ... ool,2.html
Viry mohou zpomalit počítač, nebo se snaží ukrást vaše data, a ani nevíte , že je máte. Co potřebujete, je rychlý a snadný způsob, jak je najít a zbavit se jich, pokud již máte antivirový program v počítači nainstalován , můžete nainstalovat i nástroj Sophos Virus Removal , který identifikuje a vyčistí zbylé infekce, které mohl Váš antivirový program přehlédnout.
K použití Sophos Virus Removal Tool na něj poklepejte a stiskněte tlačítko „Start scanning“ . Pak bude Sophos Virus Removal Tool vyhledávat a odstraňovat viry, které najde. Může být vyžadován restart.
Pokud byly nalezeny viry , tak po skenu klikni na „Details…“ a potom na „View log file“. Zkopíruj celý log a vlož ho sem. Potom zavři „threat detail“ a klikni na „Start cleanup“.
Jinak se log nachází zde:
C:\ProgramData\Sophos\Sophos Virus Removal Tool\Logs
http://www.adlice.com/download/roguekiller/
http://www.bleepingcomputer.com/download/roguekiller/
na svojí plochu.
- - klikni na „Scan“. V novém okně nic neměň a klikni dole na „Start“ ve sloupci „Quick Scan“
- Program skenuje procesy PC. Po proskenování klikni na „Results “ , v dalším okně pak levým t. na „Export“ a vyber : „Text File“ , log nazvi třeb RK a ulož do dokumentů nebo na plochu. Otevři soubor a celý obsah logu sem zkopíruj.
-pokud bude mít log více než 60.000 znaků , rozděl ho a vlož do více příspěvků
na svojí plochu.
na svojí plochu.
# Build: 08-30-2022
# Mode: Scan
# Start: 12-03-2022
# Duration: 00:00:37
# Scanned: 32098
# Detected: 5
***** [ DLL ] *****
***** [ WMI ] *****
AdwCleaner[S01].txt - [1748 octets] - [02/12/2022 09:24:54]
########## EOF - C:\AdwCleaner\Logs\AdwCleaner[S02].txt ##########
# Build: 08-30-2022
# Mode: Scan
# Start: 12-03-2022
# Scanned: 32098
# Detected: 5
***** [ DLL ] *****
***** [ WMI ] *****
Getting user folders.
Stopping running processes.
Emptying Temp folders.
User: All Users
User: Default
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: Otto
->Temporary Internet Files folder emptied: 610313 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 0 bytes
->Google Chrome cache emptied: 0 bytes
->Flash cache emptied: 0 bytes
User: Public
User: UpdatusUser
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 5420560 bytes
%systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 0 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 0 bytes
%systemroot%\sysnative\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment folder emptied: 0 bytes
Emptying RecycleBin. Do not interrupt.
RecycleBin emptied: 0 bytes
Process complete!
Total Files Cleaned = 6,00 mb
User: All Users
User: Default
User: Default User
User: Otto
User: Public
User: UpdatusUser
Process complete!
Junkware Removal Tool (JRT) by Malwarebytes
Version: 8.1.4 (07.09.2017)
Operating System: Windows 7 Ultimate x64
Ran by Otto (Administrator) on so 03.12.2022 at 1:13:11,86
File System: 6
Successfully deleted: C:\Users\Otto\AppData\Local\Google\Chrome\User Data\Default\Extensions\bgjpfhpjcgdppjbgnpnjllokbmcdllig (Folder)
Successfully deleted: C:\Users\Otto\AppData\Local\Google\Chrome\User Data\Default\Extensions\olfeabkoenfaoljndfecamgilllcpiak (Folder)
Successfully deleted: C:\Users\Otto\AppData\Local\Google\Chrome\User Data\Default\Local Extension Settings\bgjpfhpjcgdppjbgnpnjllokbmcdllig (Folder)
Successfully deleted: C:\Users\Otto\AppData\Local\Google\Chrome\User Data\Default\Local Extension Settings\olfeabkoenfaoljndfecamgilllcpiak (Folder)
Successfully deleted: C:\Users\Otto\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\LTFACGKO (Temporary Internet Files Folder)
Successfully deleted: C:\Windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\LTFACGKO (Temporary Internet Files Folder)
Registry: 2
Successfully deleted: HKCU\Software\Google\Chrome\Extensions\bgjpfhpjcgdppjbgnpnjllokbmcdllig (Registry Key)
Successfully deleted: HKCU\Software\Google\Chrome\Extensions\olfeabkoenfaoljndfecamgilllcpiak (Registry Key)
Scan was completed on so 03.12.2022 at 1:17:53,83
End of JRT log
File System: 6
Registry: 2
End of JRT log
