Stáhni si CrystalDiskInfo
Spusť program a klikni na Úpravy-Kopírovat. Poté sem vlož pomocí Ctrl+V obsah logu.
This was probably caused by the following module: atikmdag.sys (0xFFFFF8066B35C03F)
Bugcheck code: 0x1E (0xFFFFFFFF80000003, 0xFFFFF8066B35C03F, 0x0, 0xFFFFF8065F66EAB8)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\System32\DriverStore\FileRepository\u0346830.inf_amd64_35731e557194973d\B345901\atikmdag.sys
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: atikmdag.sys Advanced Micro Devices, Inc. KMODE_EXCEPTION_NOT_HANDLED
This was probably caused by the following module: usbxhci.sys (0xFFFFF80560DA84FD)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF80560DA84FD, 0x0, 0xFFFFFFFFFFFFFFFF)
file path: C:\Windows\system32\drivers\usbxhci.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: USB XHCI Driver
The crash took place in a storage driver or controller driver. Since there is no other responsible driver detected, this could be pointing to a malfunctioning drive or corrupted disk. It's suggested that you run CHKDSK.
This was probably caused by the following module: fltmgr.sys (0xFFFFF80738CE91C0)
Bugcheck code: 0x3B (0xC0000005, 0xFFFFF80738CE91C0, 0xFFFF868AD12D0540, 0x0)
Error: SYSTEM_SERVICE_EXCEPTION
file path: C:\Windows\system32\drivers\fltmgr.sys
product: Operační systém Microsoft® Windows®
description: Microsoft Filesystem Filter Manager
Bug check description: This indicates that an exception happened while executing a routine that transitions from non-privileged code to privileged code.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a file system driver. Since there is no other responsible driver detected, this could be pointing to a malfunctioning drive or corrupted disk. It's suggested that you run CHKDSK.
zkus spustit z příkazové řádky CHKDSK
Stáhni si Slim Drivers
Pomůže ti najít a aktualizovat ovladače..
Prosím o kontrolu Vyřešeno
- jaro3
- člen Security týmu
Re: Prosím o kontrolu
CrystalDiskInfo 8.3.2 (C) 2008-2019 hiyohiyo
Crystal Dew World: https://crystalmark.info/
OS : Windows 10 Professional [10.0 Build 18363] (x64)
Date : 2020/01/10 16:03:38
+ Standardní řadič SATA AHCI [ATA]
- WDC WDS240G2G0B-00EPW0
- WDC WD10EZEX-08WN4A0
- Optiarc DVD+-RW AD-5170S
(1) WDC WD10EZEX-08WN4A0 : 1000,2 GB [0/0/0, pd1] - wd
(2) WDC WDS240G2G0B-00EPW0 : 240,0 GB [1/1/0, pd1]
Model : WDC WD10EZEX-08WN4A0
Firmware : 02.01A02
Serial Number : WD-WCC6Y7ENTVYZ
Disk Size : 1000,2 GB (8,4/137,4/1000,2/1000,2)
Buffer Size : Neznámy údaj
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ACS-3
Minor Version : ACS-3 Revision 3b
Power On Hours : 7548 hod.
Power On Count : 1075 krát
Temperature : 36 C (96 F)
Health Status : Dobrý
APM Level : 0080h [ON]
AAM Level : ----
Drive Letter : D:
01 200 200 _51 000000000000 Počet chyb čtení
03 171 169 _21 000000000968 Čas na roztočení ploten
04 _99 _99 __0 0000000005A5 Počet spuštění/zastavení
05 200 200 140 000000000000 Počet přemapovaných sektorů
07 100 253 __0 000000000000 Počet chybných hledání
09 _90 _90 __0 000000001D7C Hodin v činnosti
0A 100 100 __0 000000000000 Počet opakovaných pokusů o roztočení ploten
0B 100 100 __0 000000000000 Počet pokusů o překalibrování
0C _99 _99 __0 000000000433 Počet cyklů zapnutí zařízení
C0 200 200 __0 0000000001A2 Počet vypnutí disku
C1 198 198 __0 000000001E56 Počet cyklů načítání/vymazání
C2 107 _91 __0 000000000024 Teplota
C4 200 200 __0 000000000000 Počet udalostí s číslem realokování sektorů
C5 200 200 __0 000000000000 Počet podezřelých sektorů
C6 200 200 __0 000000000000 Počet neopravitelných sektorů
C7 200 200 __0 00000000000D Počet chyb v kontrolním součtu UltraDMA
C8 200 200 __0 000000000000 Počet chyb při zápisu sektorů
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2057 442D 5743 4336 5937 454E 5456 595A
020: 0000 0000 0000 3032 2E30 3141 3032 5744 4320 5744
030: 3130 455A 4558 2D30 3857 4E34 4130 2020 2020 2020
050: 4001 0000 0000 0006 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0D00
070: 0000 0000 0000 0000 0000 001F 9D0E 0006 004C 0040
080: 07FE 001F 346B 7D09 6123 3469 BC09 6123 203F 803C
090: 803C 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5001 4EE2
110: 64F6 396F 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
200: 0000 0000 0000 0000 0000 0000 3035 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 107E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 90A5
000: 10 00 01 2F 00 C8 C8 00 00 00 00 00 00 00 03 27
010: 00 AB A9 68 09 00 00 00 00 00 04 32 00 63 63 A5
020: 05 00 00 00 00 00 05 33 00 C8 C8 00 00 00 00 00
030: 00 00 07 2E 00 64 FD 00 00 00 00 00 00 00 09 32
040: 00 5A 5A 7C 1D 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 63 63 33 04 00 00 00 00 00 C0 32
070: 00 C8 C8 A2 01 00 00 00 00 00 C1 32 00 C6 C6 56
080: 1E 00 00 00 00 00 C2 22 00 6B 5B 24 00 00 00 00
090: 00 00 C4 32 00 C8 C8 00 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 00 00 00 00 00 00 00 C6 30 00 C8 C8 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 0D 00 00 00 00
0C0: 00 00 C8 08 00 C8 C8 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 A8 2A 01 7B
170: 03 00 01 00 02 72 05 00 00 00 00 00 00 00 00 00
180: 00 00 01 02 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B2
000: 10 00 01 33 C8 C8 00 00 00 00 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 64 64 00 00 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 C8 C8 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 85
Model : WDC WDS240G2G0B-00EPW0
Firmware : UJ510000
Serial Number : 19425V441505
Disk Size : 240,0 GB (8,4/137,4/240,0/240,0)
Queue Depth : 32
# of Sectors : 468877312
Rotation Rate : ---- (SSD)
Major Version : ACS-2
Minor Version : ACS-2 Revision 3
Power On Hours : 306 hod.
Power On Count : 39 krát
Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM, DevSleep
APM Level : 0000h [OFF]
AAM Level : ----
Drive Letter : C:
05 100 100 __0 000000000000 Počet přemapovaných sektorů
09 100 100 __0 000000000132 Hodin v činnosti
0C 100 100 __0 000000000027 Počet cyklů zapnutí zařízení
A5 100 100 __0 000000000211 Specifický pro výrobce
A6 100 100 __0 000000000001 Specifický pro výrobce
A7 100 100 __0 000000000000 Specifický pro výrobce
A8 100 100 __0 000000000004 Specifický pro výrobce
A9 100 100 __0 000000000206 Specifický pro výrobce
AA 100 100 __0 000000000000 Specifický pro výrobce
AB 100 100 __0 000000000000 Specifický pro výrobce
AC 100 100 __0 000000000000 Specifický pro výrobce
AD 100 100 __0 000000000001 Specifický pro výrobce
AE 100 100 __0 000000000006 Specifický pro výrobce
B8 100 100 __0 000000000000 Specifický pro výrobce
BB 100 100 __0 000000000000 Specifický pro výrobce
BC 100 100 __0 000000000000 Specifický pro výrobce
C2 _64 _47 __0 002F000F0024 Teplota
C7 100 100 __0 000000000000 Specifický pro výrobce
E6 100 100 __0 013300140133 Specifický pro výrobce
E8 100 100 __5 000000000064 Specifický pro výrobce
E9 100 100 __0 000000000179 Specifický pro výrobce
EA 100 100 __0 000000000FC4 Specifický pro výrobce
F1 100 100 __0 000000000684 Total Host Writes
F2 100 100 __0 000000000204 Total Host Reads
F4 __0 100 __0 000000000000 Specifický pro výrobce
0 1 2 3 4 5 6 7 8 9
010: 3139 3432 3556 3434 3135 3035 2020 2020 2020 2020
020: 0000 0000 0000 554A 3531 3030 3030 5744 4320 5744
030: 5332 3430 4732 4730 422D 3030 4550 5730 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8001 4000 2F00
050: 4000 0200 0000 0006 3FFF 0010 003F FC10 00FB 9101
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 5E00
070: 0000 0000 0000 0000 0000 001F 850E 0006 0148 0040
080: 03F0 0110 346B 7D09 4123 3469 BC01 4123 407F 0001
090: 0000 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 8000 1BF2 0000 0000 0000 0008 4000 0000 5001 B444
110: A80E 39D2 0000 0000 0000 0000 0000 0000 0000 411C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0009 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0007 0001
170: 0000 0000 0000 0000 0000 0000 2020 2020 2020 2020
180: 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020
190: 2020 2020 2020 2020 2020 2020 2020 2020 2020 2020
200: 2020 2020 2020 2020 2020 2020 0000 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 10FF 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0010 0010 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 0BA5
000: 01 00 05 32 00 64 64 00 00 00 00 00 00 00 09 32
010: 00 64 64 32 01 00 00 00 00 00 0C 32 00 64 64 27
020: 00 00 00 00 00 00 A5 32 00 64 64 11 02 00 00 00
030: 00 00 A6 32 00 64 64 01 00 00 00 00 00 00 A7 32
040: 00 64 64 00 00 00 00 00 00 00 A8 32 00 64 64 04
050: 00 00 00 00 00 00 A9 32 00 64 64 06 02 00 00 00
060: 00 00 AA 32 00 64 64 00 00 00 00 00 00 00 AB 32
070: 00 64 64 00 00 00 00 00 00 00 AC 32 00 64 64 00
080: 00 00 00 00 00 00 AD 32 00 64 64 01 00 00 00 00
090: 00 00 AE 32 00 64 64 06 00 00 00 00 00 00 B8 32
0A0: 00 64 64 00 00 00 00 00 00 00 BB 32 00 64 64 00
0B0: 00 00 00 00 00 00 BC 32 00 64 64 00 00 00 00 00
0C0: 00 00 C2 22 00 40 2F 24 00 0F 00 2F 00 00 C7 32
0D0: 00 64 64 00 00 00 00 00 00 00 E6 32 00 64 64 33
0E0: 01 14 00 33 01 00 E8 33 00 64 64 64 00 00 00 00
0F0: 00 04 E9 32 00 64 64 79 01 00 00 00 00 00 EA 32
100: 00 64 64 C4 0F 00 00 00 00 00 F1 30 00 64 64 84
110: 06 00 00 00 00 00 F2 30 00 64 64 04 02 00 00 00
120: 00 00 F4 32 00 00 64 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 20 78 00 00 15
170: 03 00 01 00 02 2A 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FB
000: 01 00 05 00 00 00 00 00 00 00 00 00 00 00 09 00
010: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
020: 00 00 00 00 00 00 A5 00 00 00 00 00 00 00 00 00
030: 00 00 AB 00 00 00 00 00 00 00 00 00 00 00 AC 00
040: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00
050: 00 00 00 00 00 00 AE 00 00 00 00 00 00 00 00 00
060: 00 00 BB 00 00 00 00 00 00 00 00 00 00 00 C2 00
070: 00 00 00 00 00 00 00 00 00 00 E6 00 00 00 00 00
080: 00 00 00 00 00 00 E8 05 00 00 00 00 00 00 00 00
090: 00 00 EA 00 00 00 00 00 00 00 00 00 00 00 F1 00
0A0: 00 00 00 00 00 00 00 00 00 00 F2 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 71
Firmware : 02.01A02
Queue Depth : 32
AAM Level : ----
Drive Letter : D:
0 1 2 3 4 5 6 7 8 9
Firmware : UJ510000
Queue Depth : 32
AAM Level : ----
Drive Letter : C:
0 1 2 3 4 5 6 7 8 9
Základní deska: B450 PRO GAMING ,CPU Ryzen 7 2700,GPU Nvidia RTX 3060,Patriot Viper Steel 32GB KIT DDR4 3600Mhz CL18,Zdroj:VERO M2 600W / Case: SilentiumPC Signum SG1X TG RGB
- jaro3
Pak napiš , co ovladače , memtest.
případně někam pošli obsah složky:
C:\windows\minidump , zkopíruj a zararuj.
tak ten slim drivers update jde jen,když se koupí. použil jsem na stejném odkazu, níže winzip driver. když, jsem pustil testově adwcleaner hlásí spousta pup - mám to brát tak, že to hlásí, že to nemá podpis ?
hodím ti to sem:
# Malwarebytes AdwCleaner 8.0.1.0
# Build: 12-17-2019
# Database: 2020-01-06.1 (Cloud)
# Support: https://www.malwarebytes.com/support
# Mode: Scan
# Start: 01-10-2020
# Duration: 00:00:11
# OS: Windows 10 Pro
# Scanned: 34757
# Detected: 47
***** [ Services ] *****
PUP.Optional.WinZipRegistryOptimizer WinZip Smart Monitor Service
***** [ Folders ] *****
PUP.Optional.Legacy C:\Program Files\WinZip Smart Monitor
PUP.Optional.Legacy C:\Program Files\slimcleaner plus
PUP.Optional.Legacy C:\ProgramData\Microsoft\Windows\Start Menu\Programs\WinZip\WinZip Driver Updater
PUP.Optional.Legacy C:\ProgramData\Microsoft\Windows\Start Menu\Programs\slimcleaner plus
PUP.Optional.Legacy C:\ProgramData\WinZip\WinZip Driver Updater
PUP.Optional.Legacy C:\ProgramData\WinZip\WinZip Smart Monitor
PUP.Optional.Legacy C:\Users\Public\Documents\Downloaded Installers
PUP.Optional.Legacy C:\Users\virtu\AppData\Local\Downloaded Installers
PUP.Optional.SlimCleanerPlus C:\ProgramData\slimware utilities inc
PUP.Optional.SlimCleanerPlus C:\Users\virtu\AppData\Local\slimware utilities inc
PUP.Optional.WinZipDriverUpdater C:\Program Files\WinZip Driver Updater
***** [ Files ] *****
PUP.Optional.Legacy C:\Users\Public\Desktop\slimcleaner plus.lnk
PUP.Optional.WinZipDriverUpdater C:\Users\Public\Desktop\WinZip Driver Updater.lnk
***** [ DLL ] *****
No malicious DLLs found.
***** [ WMI ] *****
No malicious WMI found.
***** [ Shortcuts ] *****
No malicious shortcuts found.
***** [ Tasks ] *****
PUP.Adware.Heuristic C:\Windows\System32\Tasks\SlimCleaner Plus (Scheduled Scan)
PUP.Adware.Heuristic C:\Windows\System32\Tasks\Start WinZip Driver Updater Check Driver Update
PUP.Adware.Heuristic C:\Windows\System32\Tasks\Start WinZip Driver Updater Update
PUP.Adware.Heuristic C:\Windows\System32\Tasks\Start WinZip Driver Updater for DESKTOP-146PD6E@virtu(logon)
PUP.Optional.SysTweak C:\Windows\System32\Tasks\START WINZIP DRIVER UPDATER SCHEDULE
***** [ Registry ] *****
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{53E98A05-49DF-4D13-944B-AC9D7BB4C95E}
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{90DDA192-8199-485B-BFB2-AAC09D9FECD0}
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{D58182A9-5D03-4C6E-8A66-7BEC93298964}
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{53E98A05-49DF-4D13-944B-AC9D7BB4C95E}
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{90DDA192-8199-485B-BFB2-AAC09D9FECD0}
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{D58182A9-5D03-4C6E-8A66-7BEC93298964}
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{DBFC4EFE-B3C1-4490-8DB7-CDD491BDB4F8}
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\SlimCleaner Plus (Scheduled Scan)
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Start WinZip Driver Updater Check Driver Update
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Start WinZip Driver Updater Update
PUP.Adware.Heuristic HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Start WinZip Driver Updater for DESKTOP-146PD6E@virtu(logon)
PUP.Optional.Legacy HKLM\Software\Classes\AppID\{149622B2-F1C5-492D-BFDF-8E5ED85854A0}
PUP.Optional.Legacy HKLM\Software\Classes\AppID\{1BD47D21-01F4-4538-9290-39FD569A0F24}
PUP.Optional.Legacy HKLM\Software\Classes\CLSID\{6DC6EE87-F3BB-40EB-BCEE-12F7D6E3EEDF}
PUP.Optional.Legacy HKLM\Software\Classes\CLSID\{959D527D-6C27-4879-A644-065526D6969C}
PUP.Optional.Legacy HKLM\Software\Classes\CLSID\{BAF87BD0-A924-4108-AFA5-A5FA720A2E86}
PUP.Optional.Legacy HKLM\Software\Classes\TypeLib\{A5FF3EB5-BF62-4D59-84DF-DC518E46FCB3}
PUP.Optional.Legacy HKLM\Software\Wow6432Node\\Classes\AppID\{149622B2-F1C5-492D-BFDF-8E5ED85854A0}
PUP.Optional.Legacy HKLM\Software\Wow6432Node\\Classes\AppID\{1BD47D21-01F4-4538-9290-39FD569A0F24}
PUP.Optional.Legacy HKLM\Software\Wow6432Node\\Classes\TypeLib\{A5FF3EB5-BF62-4D59-84DF-DC518E46FCB3}
PUP.Optional.SlimCleanerPlus HKCU\Software\SlimWare Utilities Inc
PUP.Optional.SlimCleanerPlus HKLM\Software\SlimWare Utilities Inc
PUP.Optional.SlimCleanerPlus HKLM\Software\Wow6432Node\SlimWare Utilities Inc
PUP.Optional.SysTweak HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{ECDF917F-6390-4D44-AAB3-4DA08417D664}
PUP.Optional.SysTweak HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{ECDF917F-6390-4D44-AAB3-4DA08417D664}
PUP.Optional.SysTweak HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\Start WinZip Driver Updater Schedule
PUP.Optional.WinZipDriverUpdater HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\WinZip Driver Updater
***** [ Chromium (and derivatives) ] *****
No malicious Chromium entries found.
***** [ Chromium URLs ] *****
No malicious Chromium URLs found.
***** [ Firefox (and derivatives) ] *****
No malicious Firefox entries found.
***** [ Firefox URLs ] *****
No malicious Firefox URLs found.
***** [ Preinstalled Software ] *****
Preinstalled.ASUSProductRegistration Folder C:\Program Files (x86)\ASUS\APRP
AdwCleaner[S00].txt - [1375 octets] - [06/01/2020 11:12:07]
AdwCleaner[S01].txt - [1436 octets] - [08/01/2020 13:54:50]
########## EOF - C:\AdwCleaner\Logs\AdwCleaner[S02].txt ##########
# Build: 12-17-2019
# Mode: Scan
# Start: 01-10-2020
# Scanned: 34757
# Detected: 47
***** [ DLL ] *****
***** [ WMI ] *****
- jaro3
aktualizovalo 4 ovládače na zbytek to chce zaplatit
po aktualizaci u adwcleaneru je to samé spíš to dělá paseku ty updaty driverů
- jaro3
kam poslat ? myslíš windowsu
- jaro3
Odkaz se stažením do sekce BSOD , založit téma:
viewforum.php?f=118
viewforum.php?f=118
to co se děje mě, se děje více lidem. tak to řeším ještě podle toho
- jaro3
C:\Users\virtu\Downloads\5bc3098d-63f7-4b78-88a6-b8e84d0b97bf.tmp tohle znáš?
