Zdarec,
Rufus vypisuje tento log pri otestovani SD karty. Jen me zajima, zda je KO, nebo OK.
Dekuji!
Bad Blocks: Writing test pattern 0xFF
Bad Blocks: Reading and comparing
Bad Blocks: 0
Bad Blocks: Writing test pattern 0x1C71C7
Bad Blocks: Writing test pattern 0xE38E38
Bad Blocks: Check completed, 61 bad blocks found. (0/0/61 errors)
Bad Blocks: Checking from block 0 to 60 (1 block = 512 KB)
Bad Blocks: Using offset 21568 for fake device check
Bad Blocks: Writing test pattern 0x00
Bad Blocks: 1
Bad Blocks: 2
Bad Blocks: 3
Bad Blocks: 4
Bad Blocks: 5
Bad Blocks: 6
Bad Blocks: 7
Bad Blocks: 8
Bad Blocks: 9
Bad Blocks: 10
Bad Blocks: 11
Bad Blocks: 12
Bad Blocks: 13
Bad Blocks: 14
Bad Blocks: 15
Bad Blocks: 16
Bad Blocks: 17
Bad Blocks: 18
Bad Blocks: 19
Bad Blocks: 20
Bad Blocks: 21
Bad Blocks: 22
Bad Blocks: 23
Bad Blocks: 24
Bad Blocks: 25
Bad Blocks: 26
Bad Blocks: 27
Bad Blocks: 28
Bad Blocks: 29
Bad Blocks: 30
Bad Blocks: 31
Bad Blocks: 32
Bad Blocks: 33
Bad Blocks: 34
Bad Blocks: 35
Bad Blocks: 36
Bad Blocks: 37
Bad Blocks: 38
Bad Blocks: 39
Bad Blocks: 40
Bad Blocks: 41
Bad Blocks: 42
Bad Blocks: 43
Bad Blocks: 44
Bad Blocks: 45
Bad Blocks: 46
Bad Blocks: 47
Bad Blocks: 48
Bad Blocks: 49
Bad Blocks: 50
Bad Blocks: 51
Bad Blocks: 52
Bad Blocks: 53
Bad Blocks: 54
Bad Blocks: 55
Bad Blocks: 56
Bad Blocks: 57
Bad Blocks: 58
Bad Blocks: 59
Bad Blocks: 60
Bad Blocks: 0
Clearing MBR/PBR/GPT structures...
Erasing 128 sectors
Partitioning (MBR)...
● Creating Main Data Partition (offset: 1048576, size: 29.6 MB)
Could not set drive layout: Windows error code 0x00000032
\\?\GLOBALROOT\Device\HarddiskVolume10\ was successfully mounted as F:
Re-mounted volume as F: after error
Found USB 2.0 device 'SanDisk SDDR-C531 Reader USB Device' (0781:CFCC)
NOTE: This device is a USB 3.0 device operating at lower speed...
1 device found
No volume information for drive 0x81
Disk type: Removable, Disk size: 32 MB, Sector size: 512 bytes
Cylinders: 3, Tracks per cylinder: 255, Sectors per track: 63
Partition type: SFD (Super Floppy Disk) or unpartitioned
SD problemek
SD problemek
nVidia MSI GeForce 9600 GT, 512MB
Re: SD problemek
Já každé medium, které hlásí nějakou chybu, vyhazuju.
- mmmartin
Re: SD problemek
název tématu zvolte takový, aby co nejvýstižněji charakterizoval obsah tématu. Vyvarujte se použití názvu příspěvku jako "Prosím pomooooooc", "Help", "Co s tím", "Problém s..." a podobně
Zdroj: Pravidla fóra
Uživatelé prohlížející si toto fórum: Google [Bot] a 26 hostů
