ahoj...posledni mesic mam problem s pc...vim ze mam slabou grafiku a kdyz hraju sem tam se mi rozmazou textury a musim restart...to problem neni...ale posledni mesic snad co hodinu mi pocitac uplne zmrzne a musim restart nebo se restartuje sam od sebe...uz me to docela zacina stvat...nekdy se stane ze kdyz se pc restartuje hardisku treba 30 sekund trava nez naskoci a zacne najizdet win...zadnou spinou to byt asi nemuze pac jsem delal format a pc je cistej a stejne to dela...pridavam jeste vypis z hjt ale uz fakt nevim co s tim...muze to byt i necim jinym nez hadrem???
Logfile of HijackThis v1.99.1
Scan saved at 12:28:04, on 26.4.2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\system32\RunDll32.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\ADSL\ADSL USB MODEM\dslmon.exe
C:\Program Files\Hewlett-Packard\Digital Imaging\bin\hpotdd01.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\WINDOWS\system32\wscntfy.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
D:\HJT\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.tiscali.cz/
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://www.tiscali.cz/
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Odkazy
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll
O4 - HKLM\..\Run: [Cmaudio] RunDll32 cmicnfg.cpl,CMICtrlWnd
O4 - HKLM\..\Run: [9xadiras] 9xadiras.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [OM_Monitor] C:\Program Files\OLYMPUS\OLYMPUS Master\FirstStart.exe
O4 - HKLM\..\Run: [DAEMON Tools] "C:\Program Files\DAEMON Tools\daemon.exe" -lang 1033
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKCU\..\Run: [OM_Monitor] C:\Program Files\OLYMPUS\OLYMPUS Master\Monitor.exe -NoStart
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - Global Startup: DSLMON.lnk = ?
O4 - Global Startup: hp psc 1000 series.lnk = ?
O4 - Global Startup: hpoddt01.exe.lnk = ?
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_11\bin\ssv.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O17 - HKLM\System\CCS\Services\Tcpip\..\{941CA2D1-0A28-440B-85D8-096DB8157A3A}: NameServer = 194.228.41.65 194.228.41.113
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
Kde je problem?
Evidentně máš problém s RAMkou a to konkrétně na těch dvou adresách.Možná by pomohlo jestli máš dvě jednu vyhodit a když se to bude opakovat tak druhou .
Největší životní moudro je,vědět na koho se VYSRAT a před kým POSRAT .
_______________________________________
Když píšu bez diakritiky ta je to z:
G1 Android.Root. rom Canyogen 3.6.2 Theme HTC Hero 1.4.0; SonyEricsson XperiaX10; HTC Wilfire
- Zdena.Sladky
Jak říká alias75, je v háji paměť.Zkus postup, který ti popsal. Pak buď reklamovat, je-li ještě v záruce nebo budeš muset tu vadnou vyměnit za novou.
- 2433
od RIKI22
14 pro 2023 17:30
- 1858
09 lis 2023 21:09
- 15
- 1493
03 úno 2024 12:32
- 2048
od bugs
22 čer 2023 18:39
Problém s USB - C (sluchátka)
- 1745
od Grander
06 črc 2023 15:33
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 80 hostů
