Prosím o pomoc. Společnost Acer mi vrátila noťas z reklamace na vadnou dvdrw mechaniku Sony, kterou nahradila výše zmíněnou. Mechanika čte všechna CD, ale žádné nevypálí. Nero vždy vyhodí chybu komunikace "Communication failure". Nevíte prosím někdo co s tím? Používám Nero 6.3.1.6
Připojuji poměrně dost dlouhý Nero log file:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16.12.2003 19:18:06
Nero version: 6.3.1.6
Recorder: <PIONEER DVD-RW DVR-K16RA>Version: 1.16 - HA 1 TA 0 - 6.3.1.6
Adapter driver: <atapi> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 11
Drive is autodetected - recorder class: DVD+R9 DL recorder
CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 2 TA 0 - 6.3.1.6
Adapter driver: <d347prt> HA 2
=== Scsi-Device-Map ===
DiskPeripheral : HTS424040M9AT00 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : PIONEER DVD-RW DVR-K16RA atapi Port 1 ID 0 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-K16RA E: CDRom0
Generic DVD-ROM F: CDRom1
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 510MB (523248kB)
Free physical memory: 178MB (182444kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
2.2.2006
CD-ROM (ISO)
23:54:10 #1 Text 0 File Isodoc.cpp, Line 6062
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
23:54:10 #2 Phase 90 File dlgbrnst.cpp, Line 1841
Buffer Underrun Protection activated
23:54:10 #3 Text 0 File Reader.cpp, Line 118
Reader running
23:54:10 #4 Text 0 File Writer.cpp, Line 124
Writer PIONEER DVD-RW DVR-K16RA running
23:54:10 #5 ISO9660GEN -11 File geniso.cpp, Line 3898
First writeable address = 0 (0x00000000)
23:54:10 #6 Text 0 File Burncd.cpp, Line 3198
Turn on Track-at-once, using CD-R/RW media
23:54:12 #7 Text 0 File DlgWaitCD.cpp, Line 244
Last possible write address on media: 359847 ( 79:59.72)
Last address to be written: 127366 ( 28:20.16)
23:54:12 #8 Text 0 File DlgWaitCD.cpp, Line 249
Write in overburning mode: FALSE
23:54:12 #9 Text 0 File DlgWaitCD.cpp, Line 2107
Recorder: PIONEER DVD-RW DVR-K16RA;
CDR code: 00 97 34 23; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 22 17 (LI 97:34.23), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
23:54:12 #10 Text 0 File DlgWaitCD.cpp, Line 410
>>> Protocol of DlgWaitCD activities: <<<
23:54:12 #11 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 127367 (127367) = #127367/28:18.17
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 127365 blocks [PIONEER DVD-RW DVR-K16RA]
23:54:13 #12 Text 0 File ThreadedTransferInterface.cpp, Line 982
Prepare recorder [PIONEER DVD-RW DVR-K16RA] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 261154816, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
-150 | lead-in | 0 | 0x00 | 0x41
-150 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
127367 | lead-out | 1 | 0x00 | 0x41
23:54:13 #13 Text 0 File ThreadedTransferInterface.cpp, Line 1028
Removed 2 run-out blocks from end of track 1. Length: 127367 -> 127365.
23:54:13 #14 Phase 24 File dlgbrnst.cpp, Line 1841
Caching of files started
23:54:13 #15 Text 0 File Burncd.cpp, Line 4214
Cache writing successful.
23:54:13 #16 Phase 25 File dlgbrnst.cpp, Line 1841
Caching of files completed
23:54:13 #17 Phase 36 File dlgbrnst.cpp, Line 1841
Burn process started at 20x (3 000 KB/s)
23:54:14 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2342
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
23:54:14 #19 Text 0 File Mmc.cpp, Line 19864
Set BUFE: supported -> ON
23:54:23 #20 SCSI -1024 File Cdrdrv.cpp, Line 1437
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03DF0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x08 0x03
23:54:23 #21 CDR -1024 File Writer.cpp, Line 304
23:54:23 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
23:54:23 #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
23:54:23 #24 CDR -201 File WriterStatus.cpp, Line 196
Invalid write state
PIONEER DVD-RW DVR-K16RA\H1 T0
23:54:23 #25 TRANSFER -18 File WriterStatus.cpp, Line 196
Could not perform EndTrack
23:54:23 #26 Text 0 File Mmc.cpp, Line 14708
<PIONEER DVD-RW DVR-K16RA> start Close Session
23:54:23 #27 SCSI -1047 File Cdrdrv.cpp, Line 1183
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x64
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x64 0x00
23:54:23 #28 CDR -1047 File WriterStatus.cpp, Line 245
Illegal mode for this track
23:54:23 #29 TRANSFER -19 File WriterStatus.cpp, Line 245
Could not perform Fixation
23:54:23 #30 Text 0 File WriterStatus.cpp, Line 254
falling back to disc fixation
23:54:23 #31 Text 0 File dlgbrnst.cpp, Line 1699
Set remaining time: 0:00,000 (0ms) -> OK
23:54:23 #32 Phase 38 File dlgbrnst.cpp, Line 1841
Burn process failed at 20x (3 000 KB/s)
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17.8.2001 22:07:32
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 3.8.2004 22:59:44 (Adapter driver for rec)
File 'Drivers\d347prt.sys': Ver=3.47.0.0 built by: WinDDK, size=5248 bytes, created 22.8.2004 16:31:48 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Problémy při vypalování na Pioneer DVR-K16RA
- mijaja
Level 6.5
Našel jsem tadyhle stránku na ovladače pro Pioneera, ale ten tvůj se tam nějak nevyskytuje. Ale jdou tady stáhnot ovladače Atapi pro tvou mechaniku. Nevím, nakolik to pomůže. Firmware bych neměnil, protože tím ztrácíš záruku. Ještě bych se pozastavil nad tím, že Nero tu mechaniku vidí, načátání do vyrovnávací paměti funguje, startuje vypalovací proces. A dále už při detekci disku Hardware Error. Jestli ti vypalka disky bez problémů načítá viděl bych to spíše v nastavení Nera, eventuálně v jeho přeinstalování.
- mijaja
Level 6.5
Proboha Nera 7 néééé Nero 7 je jeden z nejnedokonalejších softů na dnešním trhu. Pokud by ti bez problémů jel, byl bys první v republice a okolním vesmíru. Nero7 by ještě mělo dlouho dozrávat v dílně tvůrců. Spíše bych zkusil Nero 6.3.1.8
Možná bys měl zkusit třeba CloneDVD. Je malé a lehko jej potom odinstaluješ. Nezkoušel jsi ty ovladače? Možní by se ještě na netu někde našly přímo k tomuhle typu.
Naposledy upravil(a) mijaja dne 03 úno 2006 13:36, celkem upraveno 1 x.
Ovladače jsem včera hledal na netu aspoň 3 hodiny a na tenhle typ nic. Byl jsem i na té stránce, co jsi mi poslal. Mám doma ještě NTI, tak to zkusím, ale moc šancí tomu nedávám vzhledem k výsledkům ze Sisoft Sandry. Strašně mě se*e přístup Acera. Pošlou ti to, že to funguje a pěkný kulový. Zkusím dneska ještě jinej soft a jinak jim to posílám zpátky (už po 4) ať mi koukaj navalit zpátky peníze, když se o to nechtějí pořádně postarat. Je pořád v záruce a já nad tím nehodlám trávit hodiny... Dám ti vědět ještě jak jsem dopadl se změnami softu, kdyby nic, tak pofrčí. Co myslíš?
- mijaja
Level 6.5
Mrkni se ještě do ovládacích panelů - správce zařízení a vlastnosti mechaniky - Jaký je tam režim přenosu, DMA nebo PIO, koukni i na nastavení regionu DVD - měla by tam být 2. A taky vlastně jestli to tam píše, že zařízení funguje bez problémů, nebo jestli tam není konflikt hardware. Prostě tam mrkni na všechny možnosti, jestli nás potom něco netrkne. Vyzkoušej i změnu káblu - máš tam tu vypalku samostatně, nebo ještě s diskem?
- 2941
10 črc 2023 16:46
- 717
od Bayani
23 úno 2024 07:44
- 1346
08 led 2024 21:47
- 1377
29 srp 2023 23:09
- 11
- 1390
od BL!zZard
11 dub 2024 15:42
